No worries. I'm running a 25/30 neo as well so done it all before :)
Hey just a quicky - Did you bother adding material to either the head or block to get a better seal on the headgasket around water galleries?
I was overlaying the 2 and there is clearly a mismatch but still some landing that would probably make a seal. I was thinking about just using a little RTV around that area since the rubbery rings in the headgasket in that area won't engage on the head.
I can fairly easily add material to the head and dress it back but if you've got first hand experience of not doing it I could be talked out of the work.
Dave
I might be wrong but when i was comparing headgaskets ( RB30,25 and 26)there was one that seemed thin around a water gallery, i'm going RB26 headgasket, it looked the best fit everywhere.. :glare:
Your right, they are all thin around the front gallery :glare: , probably 2mm which isnt brilliant, someone should add all these fine details into the Guide.. just got the head back from the shop too :down:
http://stevenwelsh.site.net.au/RB30_DOHC.pdf
I didnt see anything about welding beads on the gallery, should make a new guide thats more detailed... :yes: old man reckons weld more material so im gonna do that, i know that people get away with it ( i usually dont have that luck and have to do shit twice) but i dont like taking chances, 2mm contact area sounds bit dodgey.. what did you do here Ben? bolt it down or weld extra material??
Edited by AngryRB
So after reading this I thought bugger it ill just Weld it up. Decided while I had the tig out I'd just Weld up the oil feed as well since there is zero chance of it ever going back on an rb25 block. I attached some average pics for anyone who may be interested. The old water gallery is a typically contaminated surface so be sure to run plenty of AC balance.
Edited by dave1200
  • Like 1
Yeah I knocked one up a couple of weeks ago. I'm going to run this hose to the 3/4" BSP fitting in the block since I'm going N/A. Then Vent this tube also up to the catch can (in the bottom also acting like a drain for catch can). I'll plumb the 2 rocker covers to the catch can also then run the catch can breather to the inlet to keep it legal.
  • Like 1
  • 5 months later...
  • 5 months later...
Hey guys a bit of an update.
I lost a battle with the committee and had to sell my R31. I did however decide to keep building this motor. I found a healthy R31 Rb30 and as of tonight just got the Rb25 head torqued down. I set up all the timing gear and turned up some oil restrictors before cleaning the block and giving it a coat of paint. Here's a couple of pics for anyone who's interested. I've actually set up my gopro to take time lapse photos of the build for shits and giggles which I'll whack up one day if anybody would be interested. A keen eye will spot I have used a block without the machine face where the idler pulley sits. I've made up a 5mm plate to bridge it and machine that amount off the idler to suit. Not ideal but hey we're building a budget setup.
Has anybody else noticed when you use the concentric idler in the drive side of the timing gear that you timing marks don't line up perfectly? I have trialed a second tensioner in that place and can dial in the timing marks HOWEVER this makes me nervous in the case that it slips and throws the cam timing out. Thoughts?
  • Like 2
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
