So there I was, going through some old messages when I find something interesting... Someone offering to the sell this R32 with no engine in it, for $13k...
And that was deemed expensive back then!!!
4 minutes ago, r32-25t said:
Bet there’s a lot of people who wish they could have taken that offer now
I said it to my missus, I should have taken the offer when you gave. Even entirely untouched it would be worth so much money now!
  • Like 1
It came up on my memories that on the 24 of April 2015 it hit 130,000kms and I went out and looked at what it has now which is exactly 134,500kms so in 8yrs it’s done 4,500kms
  • Like 1
tank is in the boot and plumbed and the oil filter has been moved and plumbed back up. Also now has oil in the tank ready to prime the pump
front bar is back on permanently now, I love the way that cooler looks behind the bar
  • Like 2
That's looking good Brett!
You must be super close to finished (in terms of the list, not necessarily time :P )
Once it's all back on all fours, and running, is this going to end up like a once a month car that you take for a cruise, or you're planning to still drive it as hard as it's been built to be driven and truly enjoy it?
I ask as I know some of us still love these cars for what they are/were. Whereas others are now trying to turn them into old collectible cars that should be in "private museums" and barely touched for fear of the loss of the vehicle.
It's like have a hot missus you don't oots oots once in a while.
What's the point?
I'm sure Brett will give it a oots oots lol.
It’ll be a bit of both, it’ll get driven on the street occasionally to just enjoy driving it and then taken to roll racing and a few events like that to really stretch its legs
  • Like 1
It’s not a museum piece, while being a fairly clean car it was my daily when I couldn’t afford 2 cars and it has a few stone chips and etc on it, also has 134k on the clock! No one would use a car with that many kms as a collection car lol
  • Like 2
The Commodore crew don't share your opinion, they'll put 400k km examples on blocks :P
  • Like 1
2 hours ago, Dose Pipe Sutututu said:
Just put in a Nismo dash with 30k kms on it, someone will go wow.. such low kms 😂
It’s got a nismo speedo but I made the clock say the same as the original dash
  • Like 1
21 hours ago, Dose Pipe Sutututu said:
oh noesssss
Just put your spare Nissan badges onto the XR6 Turbo
It’s already starting to become unreliable it doesn’t need Nissan added to it to make it worse
  • Haha 1
Ok so the reason I decided to cancel all Japan day is I was finishing off the last of the wiring and started to look at having to do the relays and fuses for the fuel pumps, thermo fans, trigger for the power steering pump and etc. after looking at the number of wires that were going into the car, I took a step back and thought nah f**k this there’s a better and much neater way to do this!!
insert pd16 (pdm) here and the problem is solved only issue is I now need to strip the wiring harness, remove the i/o 12 box from it and fit the pd16 instead
I got very lucky and it just happened they came into stock the day after I ordered it, now while this is a set back and will mean having to redo some work, it’ll end up being better for it
  • Like 5
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
