Think I may have found my gremlin. Was testing fuel pressure again and had 50psi at idle, pulled vac line for reg and fuel pressure didn't change. Just ordered a nismo reg and will fit that when it gets here. This would explain why it's been so rich and fouling plugs.
I currently have the same problem with mine. Was fine on dyno this morning then on the way home developed a miss fire at 4500rpm. Gappef plugs down from .7 to .5 only lowered the miss in the rpm down to 3500. Made it worse. Going to change the plugs tomorrow. And set to .55mm.
Mine where all burning good. Tuner said hose must of fell off somewhere. Boost leak. Couldn't find any off so new set of plugs first the change fuel filter and check out the height of fuel pump in tank. After that. I'm at a loss so it will be going back to tuner if I don't find the problem
Found my problem this arvo. Changed plugs didn't do anything. Pulled fuel filter out. (Aeroflow reusable one ) stainless steel screen was blocked. Changed it from 80m to 30 m took for a run and was fine. Will pull the tank on the weekend and clean it out.
Pretty sure duty cycle shouldn't be that high on 550cc squirters and 18psi on a Td06 only making 240rwkw.
Looks like the new fuel pump is required anyway
Edited by fmlycar
Nah that's way too high. 550cc should be good for over 300kw on pump. Before I was having issues I would see values around 67% even with spikes of 2-3 psi in boost. Will fit new bosch pump when it arrives and report back.
Edited by fmlycar
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
