Next Financial Yr Forecast (depending on Japanese auction results - depending on supply and demand)(kept at Grade 4B standard):-
* Non V-Spec - down 7%
* V-Spec - down 4%
* M-Spec - static
* V-Spec II - up 2%
* V-Spec II Nur - up 5%
* M-Spec Nur - up 7%
* V-Spec N1 - up 8%
* V-Spec II N1 - up 10%
** 'Tis my own time capsule for observation purposes Lol
*** As cars get older, the spectrum of quality gets wider
**** I hope there's no GFC 2.0 or oil embargo to fark this all up Lol
If the fed government changes the import rules later this year I can really see BNR34 and other cars tanking in price. Instead of the 16 year old R34 I guess lot of people will just get the R35 for 50-60K.
  • 4 weeks later...
I'm going nuts over this same issue :wacko: . I miss my GTT too much so I've been looking at a 34GTR vpsec for the last few months.
Last option is to import one.. But as you guys can imagine I'm gettin a lot of resistance from family and friends saying dont spend so much on an old car.
Also I heard rumours about govt dropping import duties since the aus car manufacturers are shutting down their plants.
Will the 34GTRs retain their value? How much should I be spending on a clean one? I'm only lookin at V-spec and above. Preferably blue. :woot:
I know this is a month-old post but I thought I'd share my experience.
I was in the same boat as you, it was really difficult to find the perfect 34 GTR locally. I wanted a V-Spec or better, low km example, and it had to be blue. I gave up looking and contacted Ben over at J-Spec to get the ball rolling on an import. It was a tough decision to make at the time, but looking back it turned out to be 100% the right move. It can be daunting when you have to wait 3 months to take the car home, not to mention having to send tens of thousands of $ overseas, but with a good importer they'll make the process so seamless that you stop worrying pretty quick.
Long story short, I now have an immaculate grade 4.5 Bayside Blue V-Spec, with 37,000 genuine km complete with a full service history (I'm talking every single service sheet since brand new). It cost me around $56,000 landed and complied which I thought was very fair considering I knew of 3 similar examples that sold locally during my wait time for $60,000+.
Big shout out to Top Secret Imports here in Sydney as well, they made an otherwise painful compliance process super bearable. Awesome guys to deal with.
  • Like 1
  • 3 weeks later...
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
