When I got my RB74 pads, they were rather quiet. After several months though, the right front brakes started to get a little noisy. When it got to the stage where it would squeal on every slowdown, I decided to see if I could fix it (well, I put it off for a few weeks because I'm a lazy bastard). Here's the brief rundown on how I did it.
1. Buy some red gooey anti-squeal stuff from my local spares shop.
2. Buy 1-2 sheets of 80 grit emery paper from the same shop (around $1.25 a sheet)
3. Jack car up, remove offending wheel.
4. Remove clips and springs from pads.
5. Remove pads from caliper.
6. Sand back the pads on the emery paper until the glazed surface is roughened up. There may be some scoring marks left on the pads, it's not essential to get rid of every little groove.
6a. If your discs are badly scored, get them machined. Maybe you should figure out whether or not they need machining before you sand the pads back.
7. If the discs are fine and you can be bothered, give the discs a quick once-over with the emery cloth. It's pretty difficult to make even a light indent in the discs though, so don't worry too much.
8. Put red gooey stuff all between each layer of pad and backing plate, as well as on the back of the plate that sits on the caliper piston.
9. Put pads back into the caliper after the red gooey stuff goes tacky.
10. Bend the anti-squeal spring in the opposite direction a bit, to give it more tension for when it's in place.
11. Put spring and clips back in, put wheel back on, etc etc.
12. Test everything.
13. If you crash your car for any reason, don't blame me (disclaimer).
It's weird how only my right front brake started squealing. The left front one has remained quiet all this time so I didn't bother doing that side. I only fix what's broken :)
  • 1 year later...
I had bendix ultimates and they squeeled like a beatch and drove me nuts. I went and bought some of that anti squeel spray but it didn't help me at all ( i still had anti squeel shimmy things in there though). When I changed brake pads I got LUCAS ones put in, and they have not made a single noise ever!
I'm so impressed with these pads, they stop beautifully, don't leave my rims as filthy as the bendix ones, and they don't squeek!
So there's my advice, use the Lucas pads! (I've heard the RB ones are a bit squeeky too!)
  • 1 month later...
its mainly just the dust that makes the pads squeal after awhile. i have ferrodos that are hell dusty. i just got some anti-squeal from my work, cleaned up the discs and pads, put it on the back of the pad, includin the spring and it has never sqeualed again.
I've had Ultimates, from readings I was expecting them to squeel so I bought my self a tube of PBR anti-squeal adhesive, slapped it every where over the back of the disk and antisqueel shims.
They never squeeled so it worked. :huh:
The car was only driven on the street and never saw anyhard braking.
  • 1 year later...
my ultimates used to squeel as if they were getting molested or something..
i tried the paste stuff which didnt do anything at all..
the spray worked realy well tho ;) fixed it up 100%
alltho i have a feeling the spray doesnt work for all that long ??
well the spray lasted for about 50km of driving..... :(
the spray worked realy well tho :) fixed it up 100%
    • Nah that is not actually a lot. Just painting my GTR frontend and the little bits to make sideskirts/nismo flare pieces work correctly/fit on the sedan/mount up correctly came to about $7000. Is it a lot? Sure. None of this is economical. Economy would be shelling the car and buying a 2010 Corolla to commute in. The perspective of all of this is different.
    • I have the 2025 build re003s’ on my 06 XT Forester Turbo and I quite rate them for street wet and dry
    • I don't see any issues here. I've been saying all along this is a big job, the price reflects that.  When the car comes back perfect I'm sure it will feel like money well spent.
    • Remember, take original quote. Double it. Then add a bit more. It's how any project goes.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
