KLA33E Posted July 26, 2015 Share Posted July 26, 2015 (edited) Hi all! As topic reads I am an owner of a 95' Skyline R33 Gtst. Bought it 'bout a year ago, was and still is fairly stock. mods so far is:* 3' turboback exaust* Greddy profec b boost controller* apexi filterAlso changed the coilpacks and plugs not too long ago.So anyway to my problem. Always since i bought the car it has had the famous flutter sound (off throttle) which bothered me some, and the old owner had the Ebc set at 1bar(14.5 psi) in high mode which I know is to much for the stock turbo to handle.Experienced what I Belive was R&R at a point when the Ebc was set to only 0.75bar. (11 psi)Been driving with the Ebc controller off for some time now, no more retarded timing. So with the controller switched off I get 0.64-0.67 bar.(9.5 psi)I decided to inspect the BOV to see if I could find the cause of the flutter, suspected it would be blocked, I was right. There was a metal plate in the shape of the gasket in between with some red goo around. Removed it and replaced with a new gasket and went for a drive, now the BOV opens and air gets released, though I could hear a high pitch whistle sound around 2500 rpm with 1/3 throttle applied. Boost still went to 0.64 bar.Now more recently though the car feels really slow when I go full throttle it's holding back, like I was towing somebody kind of that feel. It dosen't missfire or anything just dosen't have that punchy acceleration anymore, but when cruising on the motorwayand I give it some gas in higher gears it pulls fairly good but boost only goes strong up to 0.44-0.46 bar. I can push it so it reaches 0.52 but thats not until 6000+rpm!Can it be a boost leak? or clutch maybye?Any advice would be much appreciated!Cheers! Edited July 26, 2015 by KLA33E Link to comment https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/ Share on other sites More sharing options...
Nanogrip Posted July 27, 2015 Share Posted July 27, 2015 Good thing you removed that metal plate blocking your BOV. For your issue, it could be your boost solenoid not opening (you have EBC), BOV leaking, leaking somewhere. Or maybe you were used to having your car with higher boost, and now it is in a normal range. Link to comment https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/#findComment-7574784 Share on other sites More sharing options...
tridentt150v Posted August 2, 2015 Share Posted August 2, 2015 Did u set the plug gap to 0.8???, at 14 psi the spark would be struggling at bigger gaps. But prob not so much at 10psi. Also wondering if your BOV is partially stuck open? Link to comment https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/#findComment-7579938 Share on other sites More sharing options...
KLA33E Posted August 3, 2015 Author Share Posted August 3, 2015 (edited) Did u set the plug gap to 0.8???, at 14 psi the spark would be struggling at bigger gaps. But prob not so much at 10psi. Also wondering if your BOV is partially stuck open? Hello! Yes the plug gap is actually 0.7mm, they regap them from factory (also checked this). As for the BOV I think that might be the case actually. Sometimes I think I can hear it bleed off when still on throttle. I have Ordered a new Turbosmart Plumb back BOV. (BPV) to see if it will help. Btw i've heard that the original Nissan one does bleed off a little at throttle to recive a more linear powerband. Do you know if thats true? Edited August 3, 2015 by KLA33E Link to comment https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/#findComment-7580265 Share on other sites More sharing options...
Ben C34 Posted August 3, 2015 Share Posted August 3, 2015 True that original bov bleeds off boost. There's a hole in it. Link to comment https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/#findComment-7580273 Share on other sites More sharing options...
KLA33E Posted August 3, 2015 Author Share Posted August 3, 2015 True that original bov bleeds off boost. There's a hole in it. Ok, Thanks! I noticed that small hole when I took it of but didn't know what it's purpose was. 1 Link to comment https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/#findComment-7580286 Share on other sites More sharing options...
tridentt150v Posted August 3, 2015 Share Posted August 3, 2015 but the factory hole is not the problem of cause Link to comment https://www.sau.com.au/forums/topic/458500-r33-feels-very-slow-lately/#findComment-7580664 Share on other sites More sharing options...
