but that would leave me with a 180kw rb25 vs. 230kw rb20
but with room and potential for a lot more, down the track. but i guess you're right, the cost doesnt change just the timeframe. #FIFO
Though...typical f**k wit seller putting hectic skid shot in ad to show how well he takes care of the car
Back in my day it used to be the P plates on the window that were a giveaway...seems kids are getting dumber
  • Like 2
Just buy another 20. Will cost you like a hundred bucks + Labour
Found an rb20 head which I'm going to freshen up & recore my blown 2530 with a gtx2863. A quick tune up + labour should set me back $4k and be on my way.
4k for 4k before you see any boost
Come on son, go the 25...
Or, you could refund movie tickets of 400 people who went and saw the Independance Day sequel
Had no problems with mine after 60,000km, still boosting flawlessly on the daily
People sell cause bored with power and upgrading, no different to buying -5s and -9s second hand
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
