6 hours ago, UNR33L said:
I think that was at a dyno day in footscray, I remember they kept on turning the boost up trying to beat my car and it had like 10 runs when the rest had 3 haha. I think I made 355ish and he made 348, it was close. My mate ended up with the most from his charged XR8 (which he is stripping to sell parts off now :()
Also remember at the same joint in early 2012 when my car was stock at the SAU dyno day and somehow won with 286 lel. How the f**k.
Just found the video LOL (Oh it was TRD-666, not v12 killer)
Nah V12KLR diss appointment was at Zoom garage dyno day.
If any chequered tuning customers want to avoid disappointment - never put your car on a roller dyno lol
  • Like 1
Road surface can make a big difference but I'll believe this when I see it
On 50% 265 AD08Rs 0 degrees superstreets with a KAAZ 1.5 way I couldn't get 2nd to hold 275rwkw on most non-freeway roads
So either something not right with my setup or our power figures aren't matching up
Somethings not right
At 300rwkw my car would hook up in all gears cold
To be fair my roller dyno 250rwkw did too
You better get a lawyer son
You better get a real good one
30 minutes ago, NUTWGN said:
Increased police presence at Saturday Night Live... and not even because of hooning! Fcking alcos ruining it for us!
did people get booked?? or just bretho people?
I dont see any harm in brethos as long as they arent pinging cars. especially since its a public space and cant really setup on the freeway.
Not sure on details but the organizers posted a statement on the page saying police presence will be increased and if found with booze you'll be fined and it's now strictly no alcohol.
Then ended with
"As mentioned above there will be an increased Police presence so if you have any concerns about the legality or Road worthiness of your car please do not come. "
EDIT:: after reading the comments apparently some hero was drinking and got asked to stop by security and then tried to fight them [emoji849]
Look at all these stupid dream boats trying to sell their plates for stupid prices:
https://www.mrplates.com.au/
HER-SSV - wants 4k LOL
BULLS - wants 20k
XR008 - 12k
XXXRTD - 25k
Do they ever actually sell? f**k I should open a business of buying lame ass plates and 'selling' for 20k
1 hour ago, emts said:
Yeh was a few of those as well, I kinda get those low number ones going for a bit but not the normal 'NVEOUSR33BRAH' plates
Low numbers are rarity / wankfest amongst those who've already spent all you can on a car. They're also selling, so hard to argue they aren't worth it; no different to diamonds for jewellery - tiny pieces of rock that do absolutely nothing.
The plates Leigh posted, on the other hand, are people who think their ingenuity in spending days on www.vplates.com.au and snapping up numberplate combinations no one else already wanted should be rewarded with cash, on the basis they managed to make a 5 look like an S and so on. Begs the question how they scraped together the $700 required to buy custom plates in the first place. 88E daytraders? Heh. Heh.
Should contact one of the stupid ones, act really interested they'd be in massive shock. Then be like nah sorry too expensive, I wonder what they'd come back with "M8 I can do 10k lowest I can go!"
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
