How about a bottle of Macallan Whisky. So he can be a boss like Harvey Spectre as that is what he drinks in Suits
suitscheers.png&key=0ac82effe9de95a2679e12a96ceeb3652296ad6f0a036a4370df6d6cb58f9747
Also Raoul Silver... (Antagonist in skyfall)
Thank you for such an obscure reference derived from a mainstream film
I wouldn't call it obscure... They made pretty damn sure the viewer knew they were drinking Mac
To get his name spot on you're either obscure or OCD on details
14 hours ago, Leroy Peterson said:
so im currently torrenting a christmas horror movie from the early 80's.... when is telstra going to come and tell me to stop?
Lel, Telstra love it.
any suggestion for filthiest pubs in eastern suburbs?
so far keysborough hotel is on the list. i dont know whats in boronia or berwick or croydon etc.
added to the list: Hampton Park Tavern and Berwick Inn Hotel
The bezza (berwick pub) is good, lots of sloppyness but surprisingly good tunes & DJ.
Old classic, the irish at Knox used to be my old stomping ground as it was walking distance from home, depening on which live band you get & how much you drank they are alright. Don't go there expecting to pickup though, theres about 2 or 3 bush p igs among the sea of men.
Edited by UNR33L
Really? Think Irish was inadvertently my most successful pick up place back in the day, and they weren't binrats either
But not hard to stand out from the crowd of guys there
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
