start of 2 he had one (was actually his own car at that)
then in fast & furious (the 4th one) he builds up a BSB R34 from impound parts and it gets blown up, then steals the STI
It's so sad that you know this
  • Like 1
4 hours ago, Count Grantleyish said:
Buy a Golf R.
Buy Megane 275...
Didn't know about the sport mode in that thing...boy did that transform the car when I did...
  • Like 1
27 minutes ago, Birds said:
Buy Megane 275...
Sport mode?
Might not be available in 265 I had in France.
Haha exactly...button is way too hidden.
It was in the 265 I rented, should be in all of them...to the far right of steering wheel past where ignition barrel would normally be. Hold down for 5 seconds and off goes ESC, idle raises to 1300rpm, throttle becomes sensitive as if the flywheel has been instantly lightened, you get a more aggressive tune for more power/torque, electric steering becomes heavier and tighter. Real jerky around low speed movements but it's a whole different car when giving it stick - actually impressed me cause with sport mode off I thought it was way too docile and didn't see the fuss.
  • Like 1
3 minutes ago, Count Grantleyish said:
Ah, I remember now.
RS mode.
It's excellent in corners like I said the other day yeah?
Didn't get enough corner action to explore this but had plenty of grip when diving into turns full throttle
Yeah, was on the other side for me haha.
They do wake up a lot with RS mode, made a drive around Austrian/Swiss alps and Nordschelefie very enjoyable.
I'd go as far as say it's the best handling FF cars out there, ze Golf doesn't grip that much into turns and mine's all paw.
For everyday driving, Golf wins hand down. Unless you live in someplace with silky smooth roads.
You get a lot of car for the money, no? 43k for base model. Pretty good all rounder / daily track weapon and one of the better looking hot hatches I think.
Yep, they're lot of car for the money. And they do look good, bit of a pain driving it through small European towns at times!
New RS is coming here this year and it'll have 5 door and dual clutch transmission (option I believe) along with 4 wheel steer for both parking and spirited driving. I think it's out in Europe sometime soon?
  • Like 1
Yeah newfound respect for the French makers. I've driven Peugeots and Renaults before and this was a different class of car. I've read this car came about as part of a tender to replace the WRXs in the fleet of the national guard fast response unit, so the cars had to be more capable than those. It's no Skyline for raw fun but if you have to upgrade to the 21st century, would strongly consider.
I've thought about moving on ze Golf for one of these purely for the driving experience. With RS mode on, it doesn't feel modular like modern cars. Instead, it feels like GC/F WRX's - unfiltered fun.
Although, Golf is better in everything else IMO.
Oh and I hope Renault has sorted the cup holder issue.
D95 model can only fit a can of Red Bull and thats it. Must be their "partnership" with Red Bull F1 team :P
Haha well there is a Red Bull edition...
And all the usual French quirks. Who the hell puts cruise control near the centre console?! Red seatbelts are cool.
  • Like 1
Yeah, I remembered searching forever for the cruise button and resorted to handbook only to find it's all in French!
Then gave up and started pressing all buttons....
RS comes with a front diff which is more than most sporty FF cars... I can't remember if it was like an electric diff or mostly mech.
I like them but they bit too big and heavy for a "small" car. Probably take the Clio personally. (Not that I've driven either)
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
