2 hours ago, UNR33L said:
Yeah that's a bit of a worry, $500 item sitting in plain sight, who can be stuffed removing it every time.
Those Sony XPLODE head units were the bomb, all dem bright red LEDs before RGB came into play.. the double dinn Pioneer head units were for the rich kids
How is it different to putting a GoPro in and out? The dash cam is easier to remove
Cams are that cheap and common these days that I don't think they'd be a major haul for break ins. The kind of people breaking into my car aren't doing it for the contents anyway, just a joy ride.
Still have a brand new one of those Xplode head units sitting in my room at mum's house...motorized face and shit lol
Wasted Christmas present
It isn't, screw putting a go pro on as well every time you drive / ride lol
Off topic: mate of mine waiting to settle for 125-700k apparently, from a motorbike accident some lady smashed into him broke his arm now having problems with it even though it happened 6 years ago..
tl;dr someone hit me with their car
This looks pretty bargain - cheapest way into a GTX1060 on the go - what are ACER laptops like? I know Dezz bought some horrid laptops but can't remember brands other than MSI
https://www.harveynorman.com.au/acer-predator-helios-300-15-6-inch-gaming-laptop.html
Horrible laptop is still going strong, the issue was an old modem not being compatible with the newer wireless card technology. Upgraded home network, problem solved.
7 hours ago, Birds said:
Bullshit^
Here's what you're gonna do...when I hang up you're gonna call me back and say the complete opposite of everything you just said to me
I rarely agree with anything Hamish says, but hat is spot on. KK are rubbish. fresh donut king cinnamons any day.
  • Like 3
Daniels donuts way better than KK
Used to live so close to Daniels when I was in Clayton, probably one of the big things I miss about the area. RIP :(
That laptop isn't bad for the price, rip out the shit 1TB hard drive and put a SSD replacement in as well.
So 4 months and they still haven't sold the place we are renting, hopefully they say f**k it and keep it for a bit longer. Asking way too much 890k for a 3 bed townhouse, yes its new but everything cheaply done and nothing special.
Edited by UNR33L
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
