Hey everyone, I have been researching this topic for a while and the opinions are quite mixed,
I have a built Rb30det Neo torque monster built by Lewis engines, the head has been ported out extensively and currently has 272 cams sitting in it,
I want to downgrade my camshafts to be able to retain vct,
My end goal is to produce max torque as early as possible in the rev range (max rpm 7200)
The important bit is i want to engineer the conversion so I need to keep emissions down.
Should I
A) Downgrade to poncams 252 or 260 have heard they can pass emissions test have only heard but can anyone please confirm.
B) Put standard cams back in.
Engine specs are as follows
Lewis engine rb25/30 Neo torque monster
Extensively ported with 24psi spring upgrade
8.2cr
Rips racing plenum 90mm throttle body
Sinco manifold t3 flange
Turbosmart 50mm external waste gate
Planning on
Gtx3076r
Id1000 injectors
3 inch exhaust.
Haltech Elite
I know downgrading the cams will negate the big head work but the application for the engine has changed from a drift car to a 4wd. Any opinions would be appreciated, I will put up a build topic in the future
Cheers in advance
https://www.sau.com.au/forums/topic/459024-rb30det-neo/
Ditch the big throttle body and run a standard one. Will give a less sudden response from closed throttle.
Run a bigger exhaust. 3.5 inch will be enough. Under a 4wd you should have plenty of room to play with.
Unless you plan on running a 1.06 turbine housing on the GTX3076, consider a turbo spec that has better match of flow between hotside and coldside. Borg Warner have some pretty good offerings and prices are very good depending on what you choose. Not physically small units, but if it's sitting in a 4wd engine bay then space isn't likely a concern.
What's the advice/recommendation from Lewis about cam spec and turbo for this application?
  • Like 1
https://www.sau.com.au/forums/topic/459024-rb30det-neo/#findComment-7588186
Dale, was originally tossing up between gtx3076 with 1.06 or gtx3582 with .82 but opted for the smaller turbo.
I will have a look at the borg warner series though, and with the exhaust size I didn't want to run the 3.5 because I didn't want it to be too loud and don't think its necessary for my goal, which is not outright horsepower but good torque throught the rev range
This motor was obviously designed for a bigger turbo and with current cams was meant to have a massive midrange and top end torque
Because the application has changed I feel as though I don't want to waste the potential of the motor but at the same time be usable as a fun 4wd, the only thing that's stopping me from going all out because I want to make it street legal and engineered.
https://www.sau.com.au/forums/topic/459024-rb30det-neo/#findComment-7588197
  • 4 weeks later...
I can't understand why I don't here more discussion on this forum about twin scroll setups. If you're going the GTX3076R get it with the 1.04 Twin Scroll rear housing and get a PROPER split pulse manifold with duel wastegates etc.
I did this on my FJ20 and it runs a GT3071R with the 0.78 rear split pulse and manifold. Makes 21psi at 3500rpm and peak torque just after that yet pulls hard to make around 270rwkw. The engine is a midrange animal.
I can only imagine on the twin cam RB30 with a relatively small turbo (GTX3076R with 1.04 split pulse) You'd probably have full boost before 3000rpm and still make 320rwkw. That to me sounds like the ideal street motor. The added benefit of the proper split pulse manifolds is the improved volumetric efficiency which may negate the need for aftermarket cams at that power level all together.
https://www.sau.com.au/forums/topic/459024-rb30det-neo/#findComment-7610814
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
