What Is The Safest Way To Purchase A Car Interstate
M8
Google + telephone
Get to ringin brah and writing it all down - don't trust the hearsay of the internet. No offence intended, but if you're not prepared to do the basic background work on your own researching it etc., you're gonna have a bad time with the whole relocating a car process! It's pretty involved and takes a decent commitment of time and backup measures to ensure everything goes to plan. It's all insurance for the 40k+ or whatever you're gonna spend on the vehicle.
  • Like 1
yeah be wary of transport companies and their "pickup" services. i booked my evo in after paying in full and they arrived about 3 days later with the car staying at the guy's place
yeah and as the others have said get full comp from the second you pay for it and get receipts etc
that way you can at least report it stolen if it goes pear shaped
also check up insurance without registraiton in case it's not registered (ie insurance via VIN #)
  • 3 months later...
+1 for the fly there, drive back.
I just bought a r33 GTR from brisbane and aside from getting f**ked around by the shop i booked a pre-purchase inspection with (they literally sat around doing nothing until 4pm despite promising me they would do otherwise) it went very smoothly and i drove it back across 3 states.
Nothing bad happened except me being very paranoid to leave it alone ANNNND....i took a quick powernap in the emergency lane on the highway....only to find a tow truck pull up ahead of me and try reversing as if they were going to tow (and potentially steal it) so i just redlined it out of there.
The drive back is tedious, but there's always nice scenery and you'll feel a lot more comfortable being able to look after your car. Just make sure to get a pre-purchase inspection of course, as there could be things needing fixes that you don't wanna be stuck out in woop woop with ;p
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
