Hi I'm new to this forum had my car for about 2and a half years so have got to know my car well just a quick question I usually service my car with motul 300v chrono 10W 40 every 5000kms but while I was down south I needed to top up oil and the best I could get was penrite hpr 15w 40 semi synthetic would've used no more than about 800 ml and I'm just really worried if I done any damage to it drove about 300km since top up am I better off not driving it till I do an oil change as it seems a bit different when driving. Cars a r33Gtr with mild mods sorry if question has been asked before couldn't find a specific answer relating to my concerns. Any advice will be greatly appreciated
https://www.sau.com.au/forums/topic/459215-oil-issue/
Ryco are fine, you need a new mechanic mate. The only thing the greddy filter gives you is a big hit to the wallet that you don't need.
I bet if you opened them up internally they would be very similar if not the same type of filter material and design.
The comparison has been done between an OEM and Ryco filter and the difference between the two was not much.
https://www.sau.com.au/forums/topic/459215-oil-issue/#findComment-7594249
Mate I think you need to apply your own thoughts instead of taking what your mechanic says as gospel.
At any oil change, do you really think every last cc of oil comes out that sump plug?
Of course not, there's always going to be dilution of your new oil with old oil remaining in galleries and various pockets.
Now if you noticed some dramatic change in your car's road performance after you topped up with 800cc of different viscosity oil, I'd be more concerned how come it needed topping up at all.
  • Like 1
https://www.sau.com.au/forums/topic/459215-oil-issue/#findComment-7594269
I know not every drop comes out at oil changes I'm definitely looking for a new workshop, I thought it could be losing oil somewhere cause usually when I service I don't require any top up. As for dramatically losing performance just was told oil was to thick to flow properly but I now think that's not the case and I doubt it needs a new dyno tune after a few months. As for the filter I done some research and it's definitely not worth the extra cash so going to be using ryco filters from now on.
https://www.sau.com.au/forums/topic/459215-oil-issue/#findComment-7594301
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
