Have all the addresses and they have started making them. hopefully will be sent by monday and received a few days later.
As they arrive plz let me know so i can make sure everyone gets them
Hey Adz I would have got one but I have a dash pod for gauges. Can you PM me the details and I might buy one then mark out where I want the extra hole cut then send it back to them for 'customising'.
Already shot them off an email and their reply was for me to pay postage back to them and they will send out a new one with a gift to cover my inconvenience.
Not really in the mood to muck around, If anybody in Brisbane southside wants it, they can have it for $80
Ok guys
The people who were going to pick up from store they are ready.
They will just ask you your name and they can tick it off...
Also,
Gho5t
sskyline x2
Okooko
Ours have arrived. Plz pm me and i can give you the pick up addie from my place
My issues have been sorted, thanks Adam, appreciate your effort, Vehicle Interior Protection Co sent out the correct item and the courier picked up the R33 mat, so it didn't cost me any extra and I also received a present from them for the stuff-up :)
glad to hear it. did shoot them an email about that and that i didnt think it was right to ask for postage. they agreed!
They do look nice to
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
