So Team,
Pulled the trigger and updated from the very much loved 'Sonic' the 4 Door R33 GTST.......................
And purchased yet another 1996 Skyline (to much head shaking from my Wife!).
Picked it up here in Canberra, as it is really clean and had a good build list base to have plenty of fun in.
So what do you do when you buy a new Skyline the day after you buy it?
Take it straight to the track of course!
On the wettest day in Goulburn history.................................... Was fun in a new car though:
https://www.youtube.com/watch?t=20&v=Rrt48o6QsgY
Give me a wave if you see me!
  • Like 8
https://www.sau.com.au/forums/topic/459652-introducing-daisy-the-gtr/
^^ Yes, it has obviously been looked after, and TBH I really didn't have to buy it, but I see so many crap ones about that if the right one pops up, grab it. Wanted a 34GTR in BB but couldn't justify the extra $35K.
So, it pretty much has everything done,if you were rebuilding a car, but it has a few issues things that need changing.
Firstly it's running god damn rich... Took me about an hour to clay bar the rear bar after the track day.
So, I'll throw a Haltech, injectors and a decent pump in and an E85 flex tune, while i'm at it.
The -7 Turbos a bit small but are near new so will persevere with them.
  • Like 2
Thanks Shaun. She's a beaut. Can you please confirm it has stock AFM's? Looks like it but not 100% sure.
Also, can you remember the flow rate of the fuel pump? Looks like it may be pretty close to maxed as well.
Oh the other thing, are you able to adjust the rear shock dampers like the front? and if so how do you access the knobs?
Cheers,
James
You coming to the track day on 23rd? Be nice to see it then.
Probably!
why on earth did you buy my sway bars James, nice upgrade!!!
Yeah, itchy feet. The guy that bought the 4Door has a nice set of swaybars. Made a huge difference to the body roll.
  • Like 1
Oh Ok. How much? Miight be a baindaid solution though. Depends on what ESP come back with price wise for the Haltech.
are you going E85?
IDK how much, don't know if i still have them, but if i do i can let them go pretty cheap. I can have a look if you think you will need them though.
  • Like 1
sweet, well im back in the scene as well got rid of the projects and bought 33 Gtr as well a few months ago, any spots left in the track day?
Yeah its just a speed of the streets day.
are you going E85?
Cool, have a look and see if they are around ta.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
