Ok so, I got my 2003 V35 from the complaince shop just over two weeks now. On the way home I filled it up because the light was on for low fuel, anyway, normally when you get near full the handle will click itself off to stop you from over filling, in each of my previous cars I could get another 3-4 clicks out of the handle before it was actually full full. Now my V35, nope, didn't even click once which lead to over-filling the tank and having fuel run down the side of my car (not good needless to say) :( I thought it might have possibly been a fauly pump and or handle so I decided to just wait until next fill-up, which I had done last weekend, completely different petrol station (and pump obviously). Exact same thing happened, I even tried listening to when it was getting full but I still over-filled it. No clicks or anything again. Has anyone else had this issue? I'd really like to figure out why it's doing it because I like to completely fill my tank but don't want fuel constantly running down the side of my paintwork. :(
Edited by brentos_mentos
https://www.sau.com.au/forums/topic/459963-v35-fuel-tank-overflows/
Thanks George, had a read and good info. Never really known how it all works, but the issue I'm having is that the nossle isn't clicking off when it gets full, not even once. Even with giving it breaks when filling and trying to listen to it while filling I can't tell when it's about to overflow..
You can't hear it bubbling like a blowing bubbles into a milkshake?
Nope. That's what I tried listening for the second time filling it up and couldn't really hear much.
I can't see how this could be an issue with your car.. although it seems unlikely, I think you managed to get 2 faulty fuel bowsers.
Possibly. I would doubt it though as 2 different ones at 2 different servos.
Are you sure they fitted a fuel filler restrictor at compliance? Sounds like they didn't.
I wouldn't have a clue. Is there any way to check without ripping out the fuel tank? Because I'm sure that's a huge pain in the ass. Shouldn't they come with one from factory anyway, even in Japan?
Just work out roughly how many litres the tank will take according to his many kms you've done. Problem solved.
That was the thought in the long run if I can't figure out why it's doing it. I'd rather not have to work it out everytime I go to fill up, granted I've only had to fill it up twice so far but even then, the first time (one the way back from the compliance shop) it was on bare empty with the light on, like the needle was at the very bottom empty line and I only managed to get about 57 litres in it (I think) when everywhere I've read they have a 65L tank. So it would take a few more times to probably work out how much I can put in it from where the niddle is sitting, not to mention probably spill it a few more times. :(
Sounds about right then if you have about 8L to spare at that point.
If you can't hear the bubbling, which is definitely an obvious sound, then there may be something going on with your breather or the vapour canister. Probably from the previous owner overfilling it too. There is absolutely no advantage to filling it past the first click. At most, I gently continue to the nearest dollar, which is only about another 500mL at most. Anything more than that is asking for trouble with your vapour capture system.
Yep, I'm more than happy to just let it fill to the first click and leave it after reading the above link article. But the problem still remains, it doesn't even click once. :(
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
