Hey guys, my rotors have had their better days and are due for a change, actually that worn that they can't be machined. I have a track day coming up and don't want to risk it with those brakes flying down a straight at 200. I've read mixed reviews on all rotors, just wanted to see what everyone thought. What rotors would be recommended for slight track use but mainly a daily. Note my budget isn't the greatest !
Car is a R33 gts-t
Thanks in advance
https://www.sau.com.au/forums/topic/460013-rotors/
Over the years I've only used 3 types of rotors in my Riceline, OEM, RDA Slotted and Dimpled and DBA T3 Slotted. In my opinion there was very little difference in performance between the three as far as on the track went. I found that the main difference came to how glazed the rotors where at the end of the day (OEM glazed badly, RDA was better and DBA was even better than RDA) and NVH (OEM had little to no NVH, DBA had a little and RDA had the most)
If I had to do it all over again and price wasn't a consideration, I'd probably go the DBAs for no other reason than I like the look of the slot pattern. In reality I'd probably just go an OEM or OEM style because I'm tighter these days!
https://www.sau.com.au/forums/topic/460013-rotors/#findComment-7610257
I think that you should move down this list depending on budget and application:
1. Two piece floating rotor (PFC, Project Mu, etc)
2. Two piece rotor (DBA5000, etc)
3. One piece rotor with uni directional vanes (DBA4000, RDA, etc)
All will be suitable for light track work.
https://www.sau.com.au/forums/topic/460013-rotors/#findComment-7610267
Yeah if you want to waste even more money buy project mu.
Waste? Have had project mu on my car for years. They cope really well to track work and don't crack like I have experienced other rotors doing. The 2 piece I have on the front of my GTR have stood up really, really well. Something I cant say for their equivalent in a DBA or an RDA. So, yeah, if waste is fixing it once, properly, then waste away. You don't need to spend big dollars on Pommie stuff.
https://www.sau.com.au/forums/topic/460013-rotors/#findComment-7610838
How much are you paying for your DBA rotors? And how many times do you multiply that by for replacement and/or machining?
Not all PMu rotors are two piece they have a number of different one piece options.
Anyway there is an option there. How cheap or how hard he uses them is up to him.
https://www.sau.com.au/forums/topic/460013-rotors/#findComment-7610902
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
