Doesn't matter they will still put the engine number onto your rego papers by doing what I said
The current rta rule is you can increase the engine capacity by 20% without needing an engineers cert as long as the engine is from the same family as the original
The current rta rule is you can increase the engine capacity by 20% without needed and engineers very as long as the engine is from the same family as the original
If they put the rb30 engine number, will he then get defected for having an rb25det setup attached to it?
No because he requires the pollution gear from the r33 to be fitted to it, if he removes the pollution gear from the car then he can be defected for not having that but not for the bottom end being changed.
It's the same as fitting an ls3 into a car that had an ls1
  • 8 months later...
and now to add to that, there is also a limit of 20% increase over factory power output too, see point 2 on page 3
http://www.rms.nsw.gov.au/documents/roads/safety-rules/standards/vsi-06-light-vehicle-modifications.pdf
however if someone was to have a dyno sheet with a run done at say 50% throttle you could say hey look this is proof that the motor makes less power than the standard rb25det
Pea shooter exhaust, cam gears retarded, 7psi (or a boost leak), tune with no timing
Lots of ways to reduce power for engineering.
I drilled a hole in bung I'd used to block blow off valve to create a boost leak and passed wa pits with a setup that made twice the standard power.
  • 1 month later...
yeah but the block is older than the car
Emissions controls for the Rb are all related to the head.
Mine was engineered with a high mount gt35 and 3.5" exhaust (big mufflers, no cheats to make it quiet), but mine was done years ago and I also had to go get it emissions tested. E85 and a nice big 400 cell cat or two helps make that easier.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
