Front has Cusco Adjustable top arms, 4 different settings... it's currently set to max negitive which should be about -2.5 deg, can get -3 to -3.5 I think if you also get an accentric bolt / bushes up there.
Flip the plate on the arm and you'll get a bit more.
Max the castor untill you hit the gaurd, then back it off.
+2mm total on the front toe
Neg 1.2 on the rear
-1 total on the rear toe
  • Like 2
Yep
Pretty sure you just rock up and call the guy and they'll unlock a garage. I'll try and sort it out beforehand though. If you PM me your phone number and bring some cash on the day I'll make sure to keep a space for you.
Probably also handy for any repairs that can be done with hand tools - couple of us will be bringing our tools.
Ok guys,
Who will be there on Sunday so I can make sure we bring enough steaks! Also SAU will have a garage for people to chill out in / get out of the weather.
Matt Lowth
Potato
Simone
13 Crag
Wog
Alex
Gav
Aaron
Birds +1
Darren
Borci88
Phantc_15
srs14t
Crzy32
Anyone Else?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
