At the very least, you guys are probably doing me a favour by giving XGTRX enough crap to read back through that he'll likely lose interest and f**k off hahaha
As long as you're here I will continue pointing out your moronic logic.
Sorry I didn't know you have sole rights to this thread, nor that your opinions are the only ones that matter.
Also I see you still haven't answered the questions I asked. Why is that I wonder? Still trying to weasel your way around the main issue like you all do, typical behavior from a self serving, selfish a-hole with no consideration for the community or world you live in.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
