Disclaimer: There's a lot of people recommending to do this mod, but I haven't seen any idiotproof guides on how to do it. I'm not saying this is the best way to do this mod, it's just how i've done it - and hopefully this will help others, even if they don't follow my way 100%.
Brief overview: The general consensus is that from Factory, M35 Stageas limit throttle to 30% for up to 3 seconds after releasing the brake pedal. This can prevent good launches/coming out of corners faster. By cutting the signal wire to the ECU, we can maintain full throttle immediately after releasing the brake. It is OK to cut this wire, however you will get a Check Engine Light after some time. By rigging it up to a switch, you are able to disable/enable the mod freely.
  1. Behind the glovebox is the ECU. You will need to dissemble the passenger side interior to access this, there's other guides online on how to do this - so I will assume you have your glovebox out and are looking at the ECU.
  2. Pull the plastic off guard off the ECU connector, it clicks off the 4 tabs on each corner.
  3. Find the VIOLET wire with the BLUE stripe - you can see it in pictures 1 + 4 of this post. I cut this wire, and attached either side to a terminal block. You can pick these up from JayCar very cheaply - I used a terminal block because I don't trust myself to solder wires coming directly off the ECU.
  4. I then picked up a small, discrete ON/OFF toggle switch (also from JayCar), which I mounted in my Glovebox - see pictures 2 + 3. Lastly just attach these wires to the remaining spots on the terminal block.
  5. Test the switch while everything is apart - This way you can fix any problems before reassembling.
  6. Done!
Picture 4 of this post explains the above if anyone is unclear.
Some people have hooked this up to the reverse switch in the car, so they don't have to touch the switch ever - however I like the idea of a toggle, so I can limit throttle power when a family member/friend drives the car.
  • Like 2
https://www.sau.com.au/forums/topic/460199-m35-brake-switch-cutoff-mod/
I like it but it's going to be a bit of a stretch to flick the switch when you are driving.
Definitely - Although I think of it more as a valet switch, however. When I drive the car I leave it enabled, if I take the car to a mechanic or lend to a friend I will disable the switch.
Can also disable the mod to clear any CEL that appears. You could mount the switch wherever you like, though - It's just where I put it :)
Agreed.
Mine is a latching switch down next to my right knee; push it in, hold down brake lightly for 5 sec, push switch again to release; good to go for another week or more.
The only Violet with a white line wire I can see is the engine revs to Hicas ecu wire.
Can you take a pic of the back of the plug?
Edit, I just noticed it looks like the correct wire at the top, but the one you pointed to is not actually connected to the switch? or is it just the pic. Looks pink/white.
Never mind, I must be tired. :P
Yeah got it from the below threads haha - It's definitely the right wire, my colour perception just isn't very good lol.
Now that I'm running a MAP sensor I can do cool stuff like video what this brake mod actually does. Enjoy.
Matt
Nice videos, can clearly see what this mod does.
Edited by DrLui
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
