Want to beef up the ignition system on my R32 RB25DE+T running all the usual stage one mods..
Currently running factory coils over gapped NGK plugs...
Theres 2 worth while options..
Aftermarket Coils (Ultra-Spark, YellowJackets etc..) OR A waste spark setup KEEPING IN MIND THIS IS A + T ENGINE.
I would opt for aftermarket coils if it was a regular DET engine but because of the turbo conversion I am wondering if waste spark is the way to go on the basis that it fires twice, once per bang stroke one per suck stroke..
Whos had experience with running different setups? What works best with the +T engines?
All info appreciated! :)
Cheers again guys
https://www.sau.com.au/forums/topic/460415-waste-spark-vs-coils-for-rb2025t/
2 points.
1) The ONLY replacement coil packs worth considering are Nissan and Splitfire. Use others at your own risk.
2) Wasted spark has NO advantages, and only exists because OEMs were cheap bastards looking to get multi-coil on the cheap.
If you want to replace the coils more completely than using original type coil packs, then the GM truck coils are the sensible option.
All this has been covered literally to the death (as in on and on and on for so long as to bore us to death) on here.
  • Like 1
Have u got pics or info on botch ones?
There not botched, Im just running factory coils atm which work fine but theres a little misfire, quality aftermarket coils can help the RB engine run smoother, Ive seen the difference between standard and aftermarket coils a few times and quality aftermarket items seem to always work better, Ive seen a few waste-spark setups which work fine too
Edited by Paulusc44
Quality aftermarket only seem to work better than genuine coils as the genuine coils there compared to are 20 years old, never seen the slightest hint that bolt in aftermarkets perform any better than new oem. The ls coil is a differnt thing all together though
A couple things:
1) the only coil set up (and I currently run it) I would even consider is the Delphi D585 coils (also known as LS2 truck coils, yes American V8 coils). These coils are the hot sh*t in the custom world as they are verified to put out more joules than just about anything out there on an actual Oscilloscope. Not marketing, BS, rumors, "oh my buddy's cousin's sister runs them," actual energy readings. Mojo performance makes a COP bracket for a reasonable price for the RB26 I know. I think he offers for the 25 as well, but go to his website and ask. I think the Audi R8 coils are also supposed to be pretty good but I haven't seen any ACTUAL data on them, just hearsay and I know they fit well. Spark energy aside, the audi and ls2 coils are good ideas because they get rid of the crap factory ignitor.
2) waste spark means absolutely nothing. it's just a coil firing concurrent with another coil firing. it does nothing for the other cylinder (that spark event is "wasted" hence the name). It allows you to run an engine on 3 ignition drivers instead of 6. If anything, wastespark reduces the effectiveness of your ignition because at high rpms, your coils could potentially run out of dwell time between spark events. that is basically not going to happen but it's the only event in which wastespark/sequential ignition may make a difference. Don't confuse this with sequential injection which IS a big deal. Your stock ECU already does sequential ignition and injection. Don't mess with it.
Oscilloscopes measure Voltage not energy? I would be very surprised if it would read the secondary output current accurately without blowing up, no matter how it was measured. Sounds like hearsay to me, I want to see the youtube clip.
better price and he is in AUS http://ls2rb.com/than mojo . I went with the D514a doe
A couple things:
There's some photos of my Bosch setup - sorry for the delay!
The coils are Bosch HEC715. I bought 6 of them (brand new) from Microtech on Gladesville for $225.00.
Only issue with them is that they don't have an inbuilt igniter so you gotta get them setup through an external igniter.
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
