Im looking for some ideas on my next stage of modifications.
My current setup is as follows
340rwkw @17-18 psi on BP 98
Rb25det Neo
Stocks gasket and head bolts
Stock motor
Tomei Type B Poncams
Kinguawa T67 25G 10Cm
Nz performance Hi mount with 44mm gate pipe
Tial 44mm Gate/38mm screammer pipe
Greddy FFP
VH45 TB
Greddy Twin entry Fuel Rail
Sard 880cc Injectors
Sard fpr
2.5" cooler pipeing
Greddy Type M intercooler core
3" DUMP
Blitz Nur Spec R 76mm
Im now Looking for ideas of were to go next id like to find some more midrage power ,Ideas are
Going to a 4" dump
ADJ Exhaust Cam Gear
Possibly E85
3" cold side cooler pipeing
8cm Rear Turbo Housing
Dont reckon you'll gain too much with a cam gear. Maybe a bit.
Best bet is to piss off the GReddy plenum and go back to factory; will lose some peak power but gain heaps of midrange.
Im aiming for around the power you have now, with a TD06L2 20G, and have kept the factory plenum for exactly that reason. Am using Plazmaman piping to keep clear of high mount turbo.
Think injector size will be too small for e85, and possibly fuel pump.
Can run on e85 and see what you get?
Don't need to change cooler piping/exhaust/exhaust housing at all either.
Edited by R31 drift pig
I went greddy inlet for shorter pipeing and neater engine bay wont be changing that.
I am keen for e85 but closest pump is 45 mins from me so will need to get a 44 gal drum and store it at home.
Think injectors would be on the edge with probaly 380 ish with e85 .
Pumps will be fine 044 and 0404
I made 310rwkws with a TD06-20G on an RB20 with E85. Having run a T67 and TD06 and a billet 73HTA-TD06 on my RB25 I personally rate the 20G or the 73HTA better than the T67. Spin 20psi through one and you will make 320rwkws with a crap load more mid...though you will find you dropping the rev limit to 7,500rpm as the show is over by then.
If I can get a 10cm I will be putting the 20G back on my car and selling the T67
  • Like 1
That plenum is where you'll find the most gains with the way your engine is setup. (keeping everything else the same that is) Shorter piping is no match for the midrange that the factory plenum provides. Well proven.
And reckon you'll run out of pump around the same level as the injectors. (On e85 that is)
My tuner advised me that safe level for single 044 on e85 with is around 360-380 kw. May have to add a 2nd 044, which is easy to do with your rail.
Out of interest, what do you reckon a 20G will make on e85 on a 25?
With the tomei cams, do you loose vct? Any reason you went type b over a?
Believe they both retain VCT.
If you keep the drum off the ground with some wood or bricks, it'll be fine for 12 months.
I do the same thing, but liberty Main nth road is 5 mins away from home.
Maybe switch to e85 first and see what it makes, if you run out of injector switch to some 1000cc's, or 1200's, and add another pump if need be too.
I would like to stay with the t67 as although this is now a street car it will still see the track pluss i have a spare core for it to i just had rebuilt.
I know there is room to find torque bye getting rid of the ffp but im not willing to remove it as i just like the look and gives headway for crazy power.
I beleive a 044 will support 400 on e85 i could be wrong more then happy to add another if i need to injectors well id like to not have to change them but if need be i can.
I went type b because i got them for a good price wanted choppy idle and because race car hahah
I first built the combo as a drift car but has been transfered into a streetcar.i was looking to go 400kw like simon r32 did with my previous motor that had studs and metal hg with this motor i havent done that so dont want to put much more boost through it
I'd keep the cold side piping the same size as the turbo outlet.
The FFP seems to have varying results, I wouldn't put one on a car now but also wouldn't take one off if it's already on there.
If e85 is not convenient could do the e42 mix.
There's a post from Status here somewhere saying the 8cm doesn't seem to be that much more responsive but loses about 30 or 40kw up top so if doing something with the turbo I'd probably go to a BW or PT.
Stock cams & TB may make it feel a bit better in the mid range.
E42, more boost & maybe head studs
Loves it till it goes bang
If anything is going to stop it going bang, e85 is it. I don't understand why so many of you guys are still using that petrol crap. :P
I understand it can be hard to find in the country but a little proactive email campaign to United would have a pump fitted in no time I suspect. We need an ethanol lobbying group setup as the rollout seems to have stalled due to base stock prices skyrocketing.
As Johnny mentioned, your head studs will be the issue with that much cylinder pressure.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
