You know the dril!
Vids, pics, stories, beer!
Firstly just a MASSIVE thank you to all the volunteers and execs for putting on this event. Without you guys the events wouldn't happen, so again - thank you!
I had fun, car ran well and relaxing now with a bottle of wine!
  • Like 2
https://www.sau.com.au/forums/topic/460574-texi-wrap-up-thread/
Hahaha was good fun. Till this happened!
Oh yeah... Broken bracket - rear right lower arm - at the subframe! Without hitting anything. Hahahahahhaha
Btw. That tow - nice chap. Cost me $120 from TAFE to Rydalmere. His number is 0432 550 077 his name is Micheal. If ever need a tow.
Beware, I VOW to have Godzilla back for the next Texi run. Sitting on the sidelines is just too hard.
And for anyone thinking, oh my car isn't good enough. Well my "TEST" pass runs on Confusion, Looper 88 and Double Slalom were made in poor little Rupret my Daily FWD Mazda 3. Only aftermarket parts on him are a set of rims.
No excuse not to come out and have a go for fun!
  • Like 2
Woot!! One more to make things more interesting! The more the merrier! Heheheh [emoji12]
Btw. Thanks for pointing out the rear arm to me. [emoji4][emoji4] much appreciated.
Thanks to all who organized, helped out etc. I had a great day, car hated it kept fouling the spark plugs (Bloody Rotor's) HAHAAA
very out of touch with RWD, manual and skids!!! was still very fun, bit disappointed I didn't wreck a pair of tyres, every time I went to grab second it would either bog down or hit the boost to hard and spin me there was no inbetween :( a different diff ratio would probably help but no point as Texi was 1 off just for a bit of fun :)
Unfortunately the RX7 won't come back to Texi but if I can prevent the Stagea from blowing a P/S pump I'll definitely bring that back!!!
didn't get many photo's, still suck at getting a decent action photo HAHA........ its about time I do some proper research on the capabilities of my DSLR
  • Like 2
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
