Just went through similar shit, but a single. If you are using the stock oil feed lines on yhe twins, as far as I know, they have restrictors on the banjo fitting on the block, BUT you have to check ur oil pressure and make sure its not too much more than stock. I think on the tomei pump you can adjust the oil pressure if its too high.
Edited by XGTRX
Quite often I have had to use multiple 1mm restrictors on single setups, it's common to overfeed the bearings/journals with oil and force it out the seals, especially if the drain is compromised. Grab some 34 restrictors and try them, as the 32 doesn't run them i'm pretty sure, but understand journal turbo's need a lot more oil supply than BB cores, you might have to drill the restrictors out a bit if they are journal bearing cores.
If you can lower the pressure externally as XGTRX mentioned it might be a lot easier than mucking around with the feed to the turbos.
Set your oil pressure Via the Tomie pump according to your bearing clearances, oil weight and RPM limit for the engine internals to survive.
Then sort out your turbo oil feed restrictor.
Pointless lowering your oil pressure to suit your turbo feed if your running big bearing clearances and intend to rev to 9000......engine will just eat itself out internally if the engines oil pressure is not there at higher RPM's
The turbo oil feed rate is adjusted after you have sorted your engines working oil pressure.
  • Like 1
I'm looking to restrict my factory oil lines to my bb turbos I heard the factory 1.2 millimetre is reduced to point eight millimetre with High volume oil pumps?
Does Earls or someone sell banjo bolts with smaller orifices.
Edited by mr skidz
Ive silver soldered the inside of the fitting then drilled it out to desired size . Bit less dodgy then gluing.
definitely that's the go f**k glue, was just hoping to change a Bolt and be done.
I'm surprised there's nobody selling these things as I'm sure I'm not the first person to put ball bearing turbos on an RB with a big oil pump.
  • 5 weeks later...
Absolutely, Just want to know whether nissan chose to restrict oil flow at the block via banjo on the 34's while garrett obviously fit them on the cartridge to be sure there restricted for warranty purposes.
The difference being 1x .8mm banjo restrictor at the block vs 2x .8mm restrictors at turbo cartridges.
Just wondering under pressure if both examples/ Turbo's would see identical oil flow being dictated by the smaller .8mm oriface @ the block.
For a high volume pump setup
Edited by mr skidz
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
