So what if you own one of these (-perhaps as a daily)?
State Gov't revenue might go down as much as half a million/day if we all bought them.
So...
1) Should you be able to use your mobile phone whilst the car's going?
2) If in an accident, do you blame the car?
3) Can you send the kids off in it after programming the car's destination?
4) Is traffic law conflict going to diminish?
5) Are HWP officers going to be relocated to other duties?
6) Warning sensors should alert owners to worn tyres, suspension damage, brake issues. So the onus is on the owner should a crash occur because of of fault codes right?
https://www.sau.com.au/forums/topic/460908-self-driving-cars/
Have you seen this Ted talk Terry?
I'm not sure we'll need to worry at all about these things.
Original TED talk is here; https://www.ted.com/talks/chris_urmson_how_a_driverless_car_sees_the_road?language=en
  • Like 1
Thanks for that Christian...
Great tutorial - but many Qs answered quite yet.
7) Is onus going to be heavier on the manufacturer that sensors are operating perfectly if services are done on time?
8) Should this type of car be able to pick up pot holes so that damage to the suspension can be avoided?
Terry, Gizmodo says that Googles vehicles cannot avoid Potholes. :(
Or change driving to suit weather (ice is slippery)
And apparently they don't do too well on non Googled roads, either. :D
  • Like 1
In a fully autonomous situation, then the pedestrians were doing the wrong thing and should both die... slightly off topic but pedestrians need to understand that 100kg v 1500kg is a rigged fight.
​back on topic, this could never be a reality without heavy subsidy due to socio-economics
​The Tokyo Motor Show theme this year is Smart Mobility, and most of the concept cars were self-driving.
1) Yes and drink and party or sleep,
2) Manufacturer for sure
3) I'm no parent, but maybe if they had missile defence systems to avoid hijacking
4) Absolutely - so would see a rise in rego? or drop in road maintenance/advancements
5) Probably redundancy
6) Would definately require rigorous maintenance, ie. high cost.
Frankly, I wouldn't trust Volvo to get it too right.
I recall reading about their press release of a model feature auto emergency braking. One of the journos thought he would try it out; the car crashed into the car it was following!!!!!
But really, all this gadgetry is, I believe, half the problem now. Drivers are now believing themselves to be indestructable now that the car drives itself, brakes for itself, brakes don't lock, can't lose control in a swerve, etc.
Really, the only truly safe car is one with an attentive, skilled driver behind the wheel.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
