Hi All, I wanted to share this with you to get your thoughts on any issues which some of you may have encountered before. I will try to be as brief as possible and include as much detail.
Subject Vehicle: 1995 GTS-T RB25DET NISSAN SKYLINE
Vehicle drives great when under soft accelaration, when I increase accelaration too hard I need to back off because it starts surging, when I back off the throttle until I find that point where it runs great and then continue to accelarate, more noticable when car is under load 40km 4th gear throttle increased - it does this in all gears when throttle increased too much.
Current Spec:
Apexi Power FC V5.10 ECU
Stock Hitachi Turbo - High Flowed - running dual stage Low 7psi High 12psi
Stock AFM
Stock Injectors
Stock Fuel Pump
Stock FPR
Stock Dump Pipe
Stock Coilpacks
Large Front Mount Intercooler
Aftermarket Air Filter (Pod)
Twin Kakimoto Exhaust Cat Back
The vehicle does this in either low or higher boost setting - it just appears that it is getting too much air not enough fuel for that throttle position - I have never had the throttle past half way without it doing this.
1. Early next week I will be putting a wideband in to see what AFR readings I get when this occurs.
2. I wouldnt have thought fuel flow and pressure would be an issue running such low boost - stock is 43.5psi with additional 12psi to accomodate boost load which is only 55.5psi that the fuel pressure needs to be when at full boost.
3. Last night I logged the current ECU maps and tested in various load ratings and throttle positions and also logged the data, I cheked this in replay mode but I couldnt see anything major jumping out at me when this surging was occuring.
Any constructive thoughts would be great
https://www.sau.com.au/forums/topic/461099-r33-gts-t-throttle-response-issues/
Hi Ben,
No from the moment I purchased the vehicle it has always had this issue. I presumed it may have been from the small modifications and not having a re-tune to allow for these mods.
I have maintained hosing and connections from the turbo outlet to intercooler to the manifold inlet - but never actually tested any additional manifold area's where it could leak.
I'll check this out.
Thanks Ben
Edited by tuning_vs_hardware
Hi Callan,
It doesn't misfire or appear to have any spark issues, no backfiring type problems when the surging happens. Im presuming coil pack or spark failure would tend to show signs of backfire issues with excess unburnt fuel, which would cause some form of firing issue.
New plugs not too long ago - Gapped to 0.9 - Never changed the coilpacks
I'm in the middle of upgrades now and just wanted to try and teeth out this issue before these upgrades. Which also consists new plugs and coil packs as well
After reading some other forums - what Ben mentioned about boost/vacuum leak almost sounds like what the issue could be. Not noticeable by ear when driving but obviously when the car ramps up I wouldn't hear it anyway. So I will run some pressure tests to see.
Car in neutral would rev to limit with no issue's - I don't free rev to the limit but just an example of how it behaves in free rev - only under increased load and throttle position it has this surging.
I'll check the pressure in the system and see for leaks - then post an update on findings
  • Like 1
Has it ever run right?
I'm going with the tried and tested boost leak is the cause of your problems. Pressure test to rule out.
Hi Ben, I have started to pull the engine down for the new upgrades and noticed some issues that I was not aware of, I guess this is the difference between just having general maintenance and not doing thorough tests.
The pressure test between the turbo to the intake manifold passed with no issues.
However when I started to pull the engine down removing the intake and exhaust manifold
I found that one vacuum hose was split right at the fitting about halfway through the hose.
The second one was where the boost gauge Tee's into another vac controlled sensor with a small little crap plastic Tee fitting which was too small for the hose it was into in the manifold - you could basically grab this without any resistance and was a very sloppy fit into the intake hose.
1. 2 x very noticeable vacuum/boost leaks
So I guess this was the issue over time as it slowly got worse the leaks were getting worse - hence the bad throttle response.
The other issues I found was the - Exhaust manifold had a large split right down the centre front face just beside where the turbo mounts. I noticed this is common
Currently have the cylinder head off and ready for the build up of the top end.
1. Aftermarket Plenum
2. 80mm Throttle Body
3. Z32 AFM
4. Top Feed 650cc Injectors
5. GTX3582R Turbo
6. Steam pipe Manifold
7. Cometic VRS
8. 45mm Turbosmart Hypergate Waste gate
9. 340LPH Fuel Pump
10. High Flow air intake
11. Ditching any performance plugs as they are a waste of money and sticking with ngk bkr6e plugs - The copper plugs are more heat resistant at higher boost plus can close the gap up on them all to aid and stop miss fire under boost
Already has Large Front Mount, Apexi Power FC, Twin Kakimoto Exhaust Cat Back
Looking forward to the new additions and some tuning/mapping to bring it all together.
Cheers
With a GTX35 I would be going iridium 8's personally, gapped to .5mm. Each to their own, there are many ways to modify cars, some better than others. You only find out if the advice you have been given is correct by putting your engine on the line.
Most of your shopping list isn't required to max out a GTX35, such as plenum, exhaust manifold large throttle etc, but I would be going larger on your injectors for when you inevitably have to go e85.
For E85, 8s are boarder line too cold.. 7s are fine.. depends on how much boost you're making.
Stock manifold is a restriction, they glow bright red on heavy load... even on E85. I'm in the process of getting a stock manifold modified venting the exhaust pressure/gases from there.
  • Like 1
Sorry to hijack thread but why do people always say you need minimum 1000cc injectors?
A simple google search of a calculator tells always that 800cc injectors are plenty good enough for 500 crank hp... Is there something I'm missing? And that's not 100% duty cycle
And yes that's on e85
Edited by Gcjosh
When your tuner sets up the parts of the map you should never see, as in when something goes wrong (too much boost, etc) he will want to dump fuel into the map for protection. If you don't have enough overhead (20% or more) it becomes dangerous.
Seeing most injectors around that size are a similar price, and most modern injectors tune up nicely at idle/cruise regardless of size there is no real reason to limit yourself with flow. You don't want to have to buy another larger set down the track if your goals change.
As Johnny said, the newer stainless internal injectors are the go these days, don't be fooled by the flow numbers, every brand test them at a different pressure so the 900cc Bosch stainless long tip injectors are called 1000's, 1050's, 1100's and 1150's, but they are all the same injector with the same flow.
  • Like 1
plugs too hot and injectors are gay :)
would go 7 heat range and at least 1150cc injectors.
Thanks for the advice,
I have 3 other choices for injectors sitting here - 850cc 1000cc and 1200cc
Chequered Tuning will be mapping the ECU and have been working close with 2 other tuners
If I am only looking for around 330KW 650cc should suffice - this was advised by a performance injector supplier - but either way when we get closer to fitting I will take everything on board as constructive comments from you guys and also the tuners to see which will be better suited. Obviously we dont want to use something that we dont need to.
Thanks Johnny
Thanks Scotty, when I pulled the engine down I noticed the stock manifold had a large crack right across the front face just beside the turbo mount position, so we opted for the top mount steam pipe manifold arrives this friday. It was 3 choices buy stock again a crap 1.6mm chinese stainless which have issue's or pay an extra amount for a quality manifold, which to me is a great investment. Many people have issue's with costing on these manifolds, when you way up the cost vs quality and the amount of work that goes into these manifolds then I think well worth it.
Thanks again
Josh,
I think some people like to be on the higher side, nothing against those wanting to say I have 1000cc injectors or 1600cc injectors. It comes down to basic formula and knowing what target hp or kw one is intending on getting out of there application. And the extra percentage headroom is always great - we dont want to stay borderline
Thats right with injector sizing and duty cycle - for 6 cylinder 450hp @ flywheel only need 492.2cc injectors running @ 80% duty cycle the calculations are endless based on sizing type of engine hp duty cycle and so on, and then bring this all together with mapping and tuning
We have chosen the 650cc for our initial sizing and have 3 higher variances to choose, that being 850cc 1000cc and 1200cc
650cc are good for about 595hp @ flywheel for 6 cylinder running @ 80% duty cycle 43.5psi - 62 lb/hr - 0.5 B.S.F.C
Should be fine come the day of tuning and mapping as we have the variances - and like the guys said especially when the time comes to go e85
Cheers Josh
you're going to regret putting in the 650cc injectors
Hi Johnny, thanks for your advice on this we have the other available sizes here on the shelf. No doubt I will be sending you a message advising we have used the 850's or 1000's - maybe we can list the top feed 650's for someone upgrading an SR20 or RB20
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
