Moving house and not knowing if I should do this but car is up for sale for a couple of weeks. If it didn't go wife says I need to keep it for the kids!
Not much to say but a great example with a genuine 50,000km. Body has never had paint and interior is as close to faultless as possible.
Let's go through the normal questions:
Rust? No
Dash bubbles? No
Holes in seats? No they look new
Steering wheel? Yep great condition
Air con vents broken? No
Original radio? YES!
No wasting time, no silly questions, someone buying a car of this standard should know what they are buying.
$37000
Cameron
0400841142post-23484-14477410953396_thumb.jpgpost-23484-14477411432711_thumb.jpgpost-23484-14477411681927_thumb.jpgpost-23484-14477411945746_thumb.jpgpost-23484-14477412180214_thumb.jpgpost-23484-14477412604367_thumb.jpg
  • Like 2
https://www.sau.com.au/forums/topic/461103-61994-gtr-immaculate-standard/
I would have bought this car but you wouldn't reply to my messages....
maybe if you used the phone number provided and called
also, calling bullshit. you wouldn't have bought shit
  • Like 1
Spoke to this guy on two occasions, each time he stuffed me around. Its ok, Iron chef helped me out and my car is on its way now. ?
  • Like 2
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
