Hey guys,
I'm an Aussie gtr owner based in Tokyo (kanagawa as of last month), and was wondering who of you also live in the land of the rising sun?
Hopefully if there are enough of us we could arrange the occasional meet up?
if you live in japan post a quick reply with your name, and area of residence in japan, and your car if you have one.
cheers!
Mish
https://www.sau.com.au/forums/topic/461150-sau-members-based-in-japan/
Totally awesome!! If you could post these pics up regularly, I'd love to share them among the social networks. We love this stuff!
Would be great to have a little SAU contingent in Japan!!
  • Like 1
For sure man, will do.
I might have to get myself a better camera and start getting quality pics.
which section would be best suited for my posts?
I've also got some tokyo car videos on my youtube page Tokyo TV
https://www.youtube.com/watch?v=gOrocIbvxFk
  • Like 1
That was awesome, well edited too.
I think posting this stuff in the Japan section and I'll promote them around the site and on FB/Twitter etc.
I absolutely *love* those EVO wagons. So freaking cool.
Those Porsches also make my knees weak!
You can post videos with [ youtube ] bbcode.
If you do add a video, please tag the thread with 'video' as we have a bit of a video index page - http://www.sau.com.au/forums/page/videos
mate, you know what kills me? when i was looking for a car in early 2012 i saw a right hand drive 993 for around 25 grand Aussie! at the time i didn't quite have the money, and was a couple of months from being ready to buy a car. the cheapest one i can find now is 50+ grand! i also saw this happen with the hakosuka, and ken&mary non gtr skylines. prices on most modern classic cars is really going up in japan!
cool mate i'll start adding more content as i get the r32 out on the wangan, and to the meets here. i'll also try to get some dyno videos from Top Secret when i get it tuned.
cheers mate!
  • 3 weeks later...
  • 2 months later...
Any more Japanese based members on here?
To bump your old thread, I'm living in Yokohama (out near Kamiooka station) and working in Minato Mirai
I have yet to experience Daikokufuto, in the past when my friend tried to take me it was closed, so we went to Tatsumi and Umihotaro.
delivered yesterday:
  • 1 month later...
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
