  • Replies 60
Posted Images
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
On 12/15/2016 at 7:17 PM, Kossac said:
sorry is the Cruise control OEM or 3rd party? Could u also quickly specify in a post what is still for sale with current pricing :) Ty!
Cruise control is a fully plug and play 3rd Party item thanks
On 12/21/2016 at 6:58 AM, 30ONA said:
Wheels pics please.
if you google 2008 infiniti g37 coupe 18" wheels its exactly those. They have a slighter lower offset than oem sedan wheels and sit more flush if you want them for a pv36.
  • 9 months later...
  • 9 months later...
  • 2 months later...
  • 1 year later...
still have these parts if anyone interested & prices updated as well.
1) V36 2010+ video in motion cable $100
3) V36 Type S and SP front lip kit ( Fibreglass sides with CF middle part, see pics) $400 ONO
4) RS-S LowDown springs BNIB $300
5) OEM Used y-pipe $50
6) OEM Used Manifold $100 (good for anyone needing to send one into z1motorsports as core unit)
7) OEM Used rear chrome bootlip $50
9) OEM Used 18" V36 Sedan Type SP wheels also in excellent condition (front tires good, rears need replacing) $400
Edited by AsM
add items
  • 4 months later...
Hi mate, Would you still have any cruise controls
  • 4 years later...
Hi AsM. Do you still have the wheels by any chance? Could you please send the pics of the wheels/condition? I tried to search the image as per your respond to another member but it came up with 2 styles. 🤔 Thanks.
