i got a black 180sx de with a type x front bar that i'm parting out. i'll sell you the shell for 3k
it includes type x tail lights, s15 rear seats, s15 front seats, neo chrome shift knob, relocated battery, slide worx coilovers (mint condition) and custom exhaust system
it's currently missing an oxy sensor and airbox
ALL WORK DONE BY GWORX
shell:3k
complete: 15k (including respray)
i dont think OP wants a car that is in pieces...
Pfft; 'sif not Flintsones to work...
Seriously though, I just bought a low km (105k) 03 Mazda 323 for $4k; it's to replace our 99 model with 265,000km. Reliable, cheap on fuel and cheap for parts.
There's tonnes around; I had the choice of about 5 within 30km from home, you can't really go wrong.
Did you find your car on Gumtree or Carsales or Something else
thanks
shell:3k
So you put a for sale ad in one section? And now you're parting it out? wut
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
