Just something to think about before you import one, if it doesn't have the aus/nz standards sticker on it some tracks/clubs won't let use it. So just double check that where you plan use it will allow it to be used
Have an old SA2000 compliant GP Jet and just after a new equivalent. Never had an issue with being allowed to use it mostly because I dont bother with the drags.
Still anyone with any ideas. Summit dont have any and other than emailing rhd Japan I havent got much of an idea.
Thanks for the tips fellas. Usually what happens is the motorbike shops don't sell the motorsport open face versions, neither do the karting places leaving you with Revolution Racegear and the like. Which don't discount stuff. Same same for overseas not many places offering Arai motorsport helmets.
That's motorbike helmets
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
