FIA unveil measures to slow down F1
Big changes proposed for 2005
From 2006, there will be a choice of engines...
The FIA has today provided the Formula One teams with details of a package of measures to reduce the performance of Formula One cars. These measures are likely to be imposed if satisfactory proposals have not been agreed by at least eight teams and presented to the FIA before 6 September 2004.
1. Aerodynamics (2005)
Diffuser height limited, front wing raised, rear wing element moved forward and changes to the bodywork immediately in front of the rear wheels. Together, these changes are estimated to reduce downforce on a current car by at least 25%, but reduce drag by less than 4%.
Explanation: lower downforce will reduce speeds, particularly in fast corners, and slightly increase braking distances, while the small reduction in drag will have a minimal effect on straight-line speeds.
2. Tyres (2005)
A driver may choose from two types of tyre, as in 2004. He will then have two sets of his chosen tyre, one for Friday and Saturday practice, the other for qualifying and the race. A damaged tyre can be replaced during the race (taken from the first set), but the car cannot be refuelled at the same time as the damaged tyre is changed.
Explanation: a tyre which must last 350 km rather than 80 km will have less grip, reducing cornering speeds, increasing braking distances and possibly producing less tyre debris or “marbles”.
3. Engine (2005)
One engine to last for two race weekends.
Explanation: both peak and average power will be less than for an engine with a shorter life.
4. Engine (2006)
2.4 litre V8 (90º) with maximum bore diameter, fixed cylinder spacing, minimum crankshaft centre line height, minimum weight and minimum height of centre of gravity. Direct fuel injection, variable geometry inlet systems, variable geometry exhaust systems, variable valve timing and variable valve lift systems all prohibited. Only one spark plug, one coil and one injector per cylinder. Exotic materials banned.
Explanation: a 20% reduction in capacity will produce a corresponding drop in power. Constraints on design and the use of materials will significantly slow the rate of power increase and reduce the scope for using engine design to improve chassis characteristics. Keeping existing cylinder sizes retains many current engine components while keeping engine revs close to current levels.
5. Other engines
During 2006 and 2007, teams which cannot obtain a 2.4 litre engine will be able to use a 3 litre V10 with power restricted by means of a rev limit fixed by the FIA.
Explanation: this will ensure that all teams (including new entrants) have access to a competitive engine, even if supplies of the new 2.4 are initially restricted.
  • Replies 40
Interesting, whats the point though really, it'll slow them down for a while.
And by the sounds of it they are trying to cut costs a bit, but at the same time, by introducing new engine and chassis designs etc they are encouraging teams to spend a heap of dollars on relearning- redesigning their systems.
So in the end, the ones that throw the most cash at engineering will win, i.e. Ferrari. Fair enough Shumacker is a good driver, but with the cash getting pumped into that team most drivers should be able to get a good result out of it. (Referring to current field of drivers, not me and you)
All in all, it should be good to see.
Engineers will ALWAYS find a way around the rules to make the cars faster. Remember when slicks were banned and groved tyres came in? Look now. The current grove tyres are better than slicks back in 97.
If drivers think the cars are too fast then they should hang up their helmets and go drive Ms Daisy.
surely their biggest problem is that 1 team is doing it so damn well atm and audience numbers are declining
a smaller problem is that there are only 18 cars competing because of the costs....but the real problem is that the audience isnt seen to be there by sponsors aren't paying up.....
Hmm,
I reckon that the v8 idea is pretty ordinary. Car speeds can easily be reduced by restricting the tires. Like i am sure a few guys on here know from personal experience it does not matter if you are running 500rwkw if you can't get traction...
And so forth. FIA is English based and i see it as anti-ferrari (italian).
There's probably some truth there... with the vast majority of teams based in the UK (Woking, Surrey is where I am!) I don't doubt that there's some concession to the other 'hard up' teams. I'd imagine the there's a bit of two faced behaviour to Ferrari from the Englanders.
One thing though is that Ferrari are a very international team, only the top end is filled full of Neapolitans.
T.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
