Shane ill be there but im flagging and helping out as SSCC are running the day. You driving??
Ill be at oran park for the next round though.
Im happy with the 6 but I know its got alot more in it once its on new tires and it becomes a bit more responsive. On the videos Im with greg in a straight line but he can pull a car length on me out of the turns untill I get the boost back up. We were running the same boost and almost identical power.
Chris I qualified in 7th was passed by 3 cars off the start as I had severe brain fade.
finished race 1 in 3rd so gained 7 positions
started race 2 in 3rd and finished in 2nd.
and finished the last race in front so I was pretty happy, was up against drivers with alot more experiance than myself in the whole grid racing schene.
Even went home with a trophy!
Its not easy going out there with 25 odd cars none of which are willing to give up a spot. And overall lap times mean bugger all in a race situation. Even doing 6's all day its bloody hard to get past a 1:08 second car!
Ive got some awesome in car footage from my car and Gregs S15 when he was carving up the field from the rear of the grid.
So many close calls in 8 laps its seriously unreal to watch how close you can be to someones bumper!
Well Done Babe :wave:
Was awesome to spectate, Was some nail biting moments for Brad and Greg and it's all on video! :P
Jay and I will hope to be doing this when we put cage's in our cars and have some more confidence/experience under our beanie's :ermm:
Update;
SAU Nickname: Marlin
Car Make and Model: R34 GTR N1
Circuit Name: Winton
Lap time: 1.35.71 (First ever lap, only allowed two)
Modifications
Engine: Std N1 spec
Power: 310 RWKW
Suspension: Proflex Tarmac Rally spec
Tyres: Dunlop DG02 Hard compound
Brakes: Custom
Body weight: 1595kg
Circuit Name: Sandown
Lap time: 1.20.12 (Third ever lap, only allowed four)
Modifications
Engine: Std N1 spec
Power: 310 RWKW
Brakes: Custom
Body weight: 1595kg
** above times taken at Dutton Rally 2007
Car Make and Model: R32 Gts-t
Lap time: 1:41.71
Modifications
Engine: Power FC and 2 1/4" exhaust only
Power: 175 RWKW
Suspension: APEXi Coil-over
Tyres: Dunlop DG02 Hard compound 205/55/16
Brakes: R33 Gts-t
Body weight: 1300kg ? or so?
Its a pretty hairy ride Chris. Im pleased but wont be stopping here. Ive got a small list of things to do over the next few weeks and the engine will be coming back out shortly. Next time down there i wont be happy unless it cracks a 5. Currently ive dropped a second every event so its more than possible.
Ill try and get the incar video up or send it to you. pretty interesting to watch.
new Phillip Island PB for me.
1.48.03
Roy, after you sober up fro Superlap, time to update the ladders.
See my sig below.
Watch out Ferni!!!!
Well done Andrew, looks like all the gremlins are gone, including the ones in your brain!!!!!!!!!
I would love to Andrew, but you need to get the moderators to allow me to become a moderator as you may have noticed that the original poster can no longer modify old posts...so i cant change the times. Up to Uncle Snowy
Doh, progess can be a bitch sometimes.
Jack, the gremlin I've got is I keep eating front right tyres for some reason. I had the front right delaminate on the inside edge on Saturday after the second timed session. It was only 3 meetings old and this is the second time it's happened. Would have been a 1.47 for sure as the track was getting faster during the day. Ask Ant, he's rapt with his time on the last session!
As per my avatar, if I put all my fastest track sectors for the day together it would have been a 1.47.6, some I'm as inconsistent as ever :P
SAU Nickname: Sl!m
Car Make and Model: R32 GTST
Circuit Name: Wakefield
Lap time: 1:15:07
Modifications
Engine: stock engine - fmic/pod/split dump pipe/gtr exhaust
Power: 160rwkw
Suspension: whiteline/bilstein setup with whiteline sway bars/cusco upper control arms
Tyres: some old semi's
Brakes: std
Body weight: std
As per my avatar, if I put all my fastest track sectors for the day together it would have been a 1.46.99, some I'm as inconsistent as ever :dry:
Small change to my time if all fastest sectors were added up. I'm encouraged as I was down about 5-10 kph in top speed, only did about half the day and the slow traffic was a nightmare. Jesus it's frustrating though :P .
Datalog attached.
Ok boys the bar has been set for a standard-ish GTR at phillip island.....I always knew it was in the car but the driver had to catch up :dry:
1.49.6887 (link: http://www.natsoft.com.au/cgi-bin/results..../2008.PHIL.S15)
Don't think there is too much left in the car the way it is....the tyres are a little worse for wear with about 1 track day left in them so I guess a fresh set would net me a couple of 10ths.
Time to start modding the suspn to see what I can do :P
Also anyone know where to find the overall laptimes on natsoft across all groups....Ferni?
Ok boys the bar has been set for a standard-ish GTR at phillip island.....I always knew it was in the car but the driver had to catch up ;)
Time to start modding the suspn to see what I can do :D
That's awesome Ant, well done! How many 49's did you run?
Normally on natsoft there is a link down the bottom combining all sessions - maybe thats just WRX sprints...
Cheers Roy.
Ferni....Just the one.....wanted to go out in another session but had no fuel left. Going by my lap timer my laps were steadily coming down until the 49 with the lap before being a 1.50.03.
Yeah I think thats just the WRX ones as I clicked on every link I could find with no luck....I'll have another look as I want to try and find the list of all laps completed as well.
Brad - yeah man send it! will be good to study your lines mate!!
SAU Nickname: evil weevil
Car Make and Model: R33 GTST
Circuit Name: Oran Park GP
Lap time: 1:29.0030
Modifications
Engine: stock engine - fmic/pod/dump pipe/exhaust/GTRS turbo, powerFC
Power: about 215rwkw
Suspension: whiteline/bilstein setup with whiteline sway bars and whiteline caster/camber/subframe
nismo 1 way diff
Tyres: falken 615's
Brakes: DBA 4000
Body weight: std
Going back in august to beat it :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
