I am in the middle of fitting my D2 6 pots to the front of my 33 GTR. I have the drivers side on, no problem. Passenger side, i have put the disk on, held it on with wheel nuts then fitted the caliper. The disk is extremely close to the inside brake pad. When i spin the disk it spins freely until a certain point then gets stiff.
I can still push it through by hand with a little bit of force then it loosens up again.
Is it going to be OK like this? If i drive it will it just wear the pad enough to stop it from rubbing?
I really don't know what else to do. The washers that come with it to space it are no good as they just push the pad even closer to the rotor.
Any ideas?
https://www.sau.com.au/forums/topic/462417-d2-brake-fitting-help/
Put it all together, bleed thoroughly, and drive back and forth (not on the road and with no hard braking) and then jack it up and see if it is still binding. I would not be keen to try to get rid of the problem by hard braking, You want it all lining up properly before you bed the pads and discs in as per instructions.
Does the piston go all the way back in? Tried levering it in (without the pad and opening the bleed screw)?
Yeah the pistons are all the way in, the whole kit is brand new.
I also had a look at the passenger side and that is pretty similar.
I have just been trying to get it straight for the last 4 hours with no luck. I have tried swapping the brackets. I have tried fitting the brackets in every way possible, you can only bolt the calipers with them one way which is the original way i put them on.
They only need to move over a tiny bit. I really don't know what else to do now.
hmm not awesome. they will still work fine but the inner pad will wear faster than it should. I think you already said the shims would worsen the problem not correct it.
Assuming all mounting surfaces are flat and straight eg no small metal dags pushing it out, your only option to correct it would be to have the adapters machined to take a mm or 3 off. Or you can just pretend it never happened and live with faster pad wear than you should have. Or return them....
OK thanks for that mate. I dont drive the car much so wear is not a huge issue, it probably does about 1000 miles a year. Although i would like it to be fitted correctly really! Yeah, the shims will just push the caliper even closer to the pad.
I am sure all mounting surfaces are flat, I will check again tomorrow though.
I am in talks with the company i bought them from who are talking to the factory that make them so will see what they say. I cant really send them back though, i have sold my brembos :(
I'm with Duncan on this one.
Once you've double checked all mounting faces are free of scale/debris, check the clearance again.
Either have the supplier send some better spec (slightly thinner) adaptor brackets, or get yours machined. Take off 0.5mm will probably resolve everything. Not a big or expensive job.
I have managed to get the brakes on properly. There was a metal nipple that was touching the mounting bracket a tiny bit which was stopping it from sitting flat against the hub. It was quite hard to see that it was touching as it was so minmal but it kept catching my eye and I had a feeling it was because of that.
I ground it down and refit the mounts, disk and calipers and they all line up perfectly!
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
