Thanks Ewan,
Glad you like them
Photo's dont do parts justice sometimes - getting light and shade reflection in the right places is hard I think out of about 200 photo's of some parts we manage to get the right lighting for the part and choose maybe 3 or 4 images to go with.
Take a pic when you have them on the car as well
Can't wait for my sets to arrive. Will get pics on 2 different cars for you when they do =)
I was just about to PM you - your second set is almost cut running the last tool path now. Then they will be booked into the polish and final finish tomorrow. Anticipating a completion by this friday
Thanks again Anthony
Just updating with some variations of the Z-Tune Badge - CNC Billet 3mm Thick - this badge dimension is 138mm x 31.5mm but can be changed to whichever size needed
  • Lower Base will be mill finished
  • Upper Edges and contours will be full polish
  • Any choice of color for the inlay
  • Also either inverted lettering or extruded version
Custom CNC Billet - Number Plate Style for Burnout Entrant Vehicle
Item will be inlayed with Black Candy and Full Polish on the Skull and Lettering - should look similar to a Black White style number plate but should pop some.
Anyone interested in Custom Show plates CNC Billet with any color and finish - can be extruded type lettering or inverted type - letters or image incorporated
Thanks All
  • Like 1
PUNISHD - Custom Number Plate
Upload of the previous images were the mill finish - this verison now has a mirrror polish
Will be inlayed with DNA Black Abyss Candy on the base around the letters and the skulls before a Crytsal Diamond Clear Over
Will upload pics when I have the final version.
Anyone interested in Custom CNC - Just send a PM
Thanks All
Shipping to the U.S.?
We ship international, if you can advise a product you are looking to order we can calculate shipping costs.
Just need a drawing, dimension or if there was an interest on a previous model you have seen that would be great.
Cheers
Hi All,
Just wanted to update post with a new customer RB26 Engine Ornament Plate
CNC Billet 6061 - Mirror Polish finish
Image captured with various reflections and light to ensure we could show the mirror finish for you all.
Looks great
Also working on some other products and should have them up soon.
Thanks
  • Like 2
Can confirm Tim does great work, highly recommend guys :yes:
Will get pics of the small badges i got made for the R hopefully this week *Crosses fingers*
  • Like 1
Hi All,
Just wanted to share a recent sample we done after supplying a customer with a polished only version.
See below image
Nissan Z-tune Badge
Custom CNC Machined 6061 Billet - Anodized Black Upper Surface Full Polish
By this friday we will have some pretty amazing pieces we can share when our customers receive the items.
Hi I am curious in to how much it will be for a total of 4 badges? I would like 1 for front (grill) 1 for rear and then 2 for rear sides of car. Oh im looking at the GTT badges (chrome and red) if you could let me know what the total will be for these please, thank you.
Hi z00key,
I will PM the costing to you regarding a set of the GTT - badges
Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
