  • Replies 121
Guest RedLineGTR
These are the only dyno charts i got on the dyno day. Sorry :(
Adzmax
Click
GTTR34
Click
Click 2
INASNT
Click
NismoR34
Click
riggaP
Click
Click ON Them in the gallery for i bigger image size.
Have a look around my gallery you might find some other pics you like.
Cheers Rob
thanks guys ive just sent out all your dyno sheets today but hear is the results as im putting your first name and the first 3 letters of your rego as im not sure who all of u are but gives u all an idear
ALL DYNO WAS DONE IN 4 GEAR
ADAM N . ADZMAX 205 RWKW R34
PAUL R . SKY 195 RWKW R33
QUOC . SVA 168 RWKW R32
KASIN S. QVR 125 RWKW 200SX
CHRIS L. QYI 249 RWKW R33
MICHAEL C. SKW 160 RWKW R33
DALE F. RXZ 190 RWKW R34
ALAN C. EXIBIT 210 RWKW R33
MATT . RZD 195 RWKW R34
DENHAM. SYT 324 RWKW R33
FETTY B. RKJ 167 RWKW R33
JASON P.RRR 375 RWKW R34
EROL B. PHT 161 RWKW 200SX
TOM G. GTS 120 RWKW R32
JARROD M. QCY 135 RWKW R32
MALCOM Z. QDR 61 RWKW SUZUKI CAP
GEOFF W. QOA 215 RWKW R33
MATTHEW T. SUA 161 RWKW
DAT . SUE 185 RWKW 180SX
WARREN C. PXZ 135 RWKW R32
SKYLINESTEVE. SYS 187 RWKW R33
SO U SHOULD ALL HAVE AN IDEAR SOME OF U I DONT HAVE AN ADDRESS FOR SO I WELL BRING YOUR SHEETS DOWN THE NEXT MEET
These are the only dyno charts i got on the dyno day. Sorry :D
Adzmax
Click
GTTR34
Click
Click 2
INASNT
Click
NismoR34
Click
riggaP
Click
Cheers Rob
Werent you taking vid as well with that camera?? Was it a SLR?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
