As instructed ........
What is everyone's thoughts?
Just got my car tuned 703rwhp 524rwkw. Does anyone know the record for these turbos?
Built bottom end with 87mm pistons
2860-5 turbos
Pon cam type A
Tomei manifolds and dumps
Apexi down pipe
ID1000s and tomei fuel rail
2 walbro 400lph fuel pumps
Nismo inlet pipes and hard intercooler pipes
Custom intake pipes
AEM series 2 ecu tuned for flex fuel
4CA2765D-A61C-43E6-9DCF-9E05E902C893_zps
Edited by Jc052685
https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/
Simply a dual 2.5" Maf-less system I built for it. I am wishing now that I used 3" as I may have left a few hp on the table. I welded 2.5" v-bands to the turbo inlets as to minimize the inlet turbulence that a couplet could induce. Took care to make sure all inlet pipe fitment was perfect.
00000000-0000-0000-0000-0000000000ED_zpsA7AF15C8-183C-4845-B030-E13041C0BC9E_zps
I personally feel that if the customer wanted to truly max out the turbos by freeing up some restriction that still exists in the inlet & charge pipe sections that I could get another 25-35whp out of them. Car is still on the factory intercooler & intake plenum after all.
These are all the performance mods I can remember.
CP pistons 87mm
Eagle rods
N1 crank
Nismo oil pump
Mild head work
BC springs/retainers
Tomei type A poncams
2860-5 turbos
Tomei dumps
Tomei manifolds
Spec twin plate
AEM ecu tuned for flex fuel
Nismo thermostat
Apexi down pipe
Aluminum Radiator
ATI dampner
Blitz cat back
Greddy cooling panel
Greddy timing belt
ID1000 injectors
Tomei fuel rail
2x Walbro E85 fuel pump
Nismo air inlet pipes
Nismo intercooler hard pipes
Powerfab intakes
Splitfire coil packs
Got a pic of the cooler, Nismo is not factory and there is two versions with one being far superior to the other
Looking at the parts list I would say the exhaust and ID1000s are the most limiting factors and would guess a realistic 400-420rwkws and give or take 130-135mph
List says Nismo cooler, factory cooler starts to measurably pressure drop from around 350kw, 500+rwkw on a stock cooler is where I call mythbusted
Car made 490whp on 13psi...... Mustered a 507whp pull at about 15psi but the 93 octane pump gas was the limiting factor.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
