Lifting base pressure 15oddpsi will see more flow for more topend
What C/R is it running
You talking about raising the fuel pressure? Its already at 58psi. Figure another 25psi when under full boost you are looking at 83psi rail pressure.
Not sure on cr
1000cc injectors is way to small for 500kw on e85.....
Or at least a Aussie 500kw that is.
This ^
I made 604hp with my -5s on my Tomei motor at 27psi (still 2.6) on E85 with 1,000cc injectors twin bosch pumps and a Walbro 460 lift pump (to surge tank) and they were almost maxed out
Most GTR-s that run -5s here in Oz make between 450-480kw max on corn syrup
I think dyno read out is a bit too optimistic IMO but we all know how to settle this don't we?
you will need a drag strip
and a go pro
and a pic of 400m..........wait..........I mean quarter mile timeslip
  • Like 3
Not sure on cr
No, I mean 58psi base is already 15odd psi higher then the base we usually see, mine is at 50psi which is already high then normal
You don't know what the compression ratio is ?
What is the smallest id of your exhaust system?
3" I believe.... And its Rickys car, just so there is no confusion.
I did not build the motor so I do not know the specifics.
most modern fuel systems run 58 or so psi. That is where we normally run things. Had this car at 43.5psi in order to help with pump gas drivability but we had to turn it up. The ID1000's are rated at about 1150cc/min at 58psi.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
