I dropped my M35 to JEZ DVS last weekend for EMU setup and tune.
JEZ already finished hard wiring work today and try to tune my car, but he found my car has stall problem:
car starts for 1 second then stalls but not always.
all inputs outputs from EMU looking good. has injector pulse, spark, fuel pressure.
he said it is a fuel issue as they can get it to start with spraying bake cleaner into the inlet manifold replaced the fuel and the engine runs for a few seconds.
currently he let battery be charged and will check cold start tomorrow.
here is my setup:
GCG highflowed turbo
HDI FMIC
Walbro pump with constant 14v
840cc denso injectors
Blitz EBC
KN air filter
scotty dump pipe
2.5" straightly catback with 100cell cat (no budget for 3" currently)
innovate wideband O2 with AF meter
anyone has idea for stall problem?? :woot::woot:
https://www.sau.com.au/forums/topic/463726-greddy-emu-setup-help/
Does it have an alarm?
yes, but you cannot start engine at all without unlock the immobiler. JEZ knows how to use the immobiler.
the problem is engine could start for 1 second then stall, not can't start at all.
Edited by YangLIU
Ignition lock problem?
Did you replace the fuel filter in the tank and in the engine bay?
Jez said injectors can't open when cranking.
I have replaced fuel filter in tank before. When is the other one in engine bay?
186.5rwkw@16psi, 194.6rwkw@19psi
currently using 2.5" catback. i will import my kakimoto 3" catback soon from Japan. also kakimoto 3" de-cat front pipe is in my garage for a while.
So thats who bought that kakimoto decat pipe.... the one on ebay?
yes it should be, it has big canon, LOL, that's why i didn't ship it to AUS so far...
I know someone local in Sydney that may be interested in selling his kakimoto. It's my old exhaust, in great condition.
Let me know if your interested and I can put you in contact
Thanks mate. I already bought kakimoto n1 from yahoo auction since last year and it is sleeping in Japan garage now. Since I have tuned my car and need 3" exhaust, I am trying to ship it back to Sydney these day.
Btw, do you know if there is big difference if I fit kakimoto 3" de-cat front pipe on my car? I am afraid of it is too loud.....
It will be epic loud. I ran a 100cell cat with mine and it was still very loud.
It did sound awesome though. Haha
I think 100cell will not give much help on this. I am afraid of the cop, you know they could easily defect your car with 100 different reason. Lol
I had no cat on my Legalis R when I bought the car.
Fitted a 100 cell cat, couldn't notice any loss in power at all (under 5000 rpm )
Also the cat didn't make it any quieter really. Maybe 3-5 dB
Just want it to be legal, plus bonus bung for tuning.
Still over 110 dB.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
