If it is looped at the back ends of the pipes.....nothing. Oil just goes round and round. The vane delete is if you want to remove all the plumbing including the stuff that runs under the engine to the rear stage of the pump. Otherwise you'd need to loop it at the pump.
I just swapped in an R34 engine (GTT -> GTSt, not GTR) and that took care of the pump! Would work the same on RB26 stuff too, seeing as hydraulic HICAS died in the arse on those too.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
