ok so, thanks for all the feed back and the companies you have used. I have done allot of shopping.
I finally landed on an insurer.
interestingly it is also NRMA classic (well its actually SGIC vintage but same same)
they went through what the cars has and all of the details and this is what I came up with:
1989 gtr 120k (haltech, wheels, exhaust, stereo, coilovers)
$30,000.00 agreed value
windscreen and glass cover
roadside assistance
choice of repairer
$44 a month
$300 excess.
I can drive it 10 times a month and must be garaged safely
im bloody happy with that price and the fact that they are happy to cover me for what I think is a good amount for my car.
don't let your gtr be uninsured. I would use my car as a baseline tbh, oldest standard model possible with minimal average mods in good condition.
Edited by GH05T
  • Like 4
  • 8 months later...
another happy little update with my policy mentioned above.
i have added my panasports in full detail to my policy cover as well as the haltech. my payments have only changed to:
$46 per month
$300 excess
$36,000 agreed value.
still very impressed, havnt made a claim yet but atleast i am not worried about my modifications untold, or if wheels get nicked, im allowed $4500 to replace the rims if they do go missing.
  • Like 4
Extra $24 a year for $6k value increase is winning in my books! Plus the cover of your listed modifications that they are now aware of. Once I get around to install the modifications with my 33 gtr I'll probably give NRMA a call and mention the mods that have been completed to keep it on record and hopefully the value might go up a smidgeon also.
  • Like 1
thats just it, if my wheels get nicked then i have $4500 to play with to replace them, as i had no receipts for them being private sale, they asked for photos on the car and all the details which is great, they hold my record of them so you dont have the response which my mate had once claiming on stolen wheels "you can buy mags for $1000 new"
aslong as you have reason to up the value they up it.
  • 4 weeks later...
Just got my Shannon's renewal in the mail ($75/month, down from $125/month) now that it's been 2 years since my encounter with Skippy.
Thought I'd still try SGIC (NRMA) VVC.......$46/month with the same $40,000 agreed value but down to a $300 excess instead of $500 with Shannon's.
Note I am saving $3-4/month due to now also switching over a couple of other policies to now have all my insurances with SGIC.
  • Like 1
  • 1 month later...
My renewal came through, and Famous have offered me $25K value, up from $14.5K at the last renewal. However, they said they may be able to go higher with a comparative quote. Yearly cost is $1150. So, clearly i should talk to SGIC/NRMA... For the following mods on a fair condition car, what value should i ask for? (or will they determine it?)
R34 GTR Wheels
Tein NA suspension
Nismo front suspension arm kits (54501-RS585-R & 54502-RS585-R)
Whiteline front and rear anti-roll bars
D2 356mm brakes
Aftermarket exhaust
Nistune
R34 GTR front seats
R34 GTR Wheels
Tein NA suspension
D2 356mm brakes
Aftermarket exhaust
Nistune
R34 GTR front seats
There will be some market value figure that NRMA will have listed for the 32 gtr's. With their current price $25k is easily achieveable if not more. Depending on what they offer you, you can ask them to raise the value, usually at a small cost but you have to 'prove' why you believe the car is worth more. Obviously not factory and modified constitutes as being worth more in value, not just maintenance costs, etc.
R34 GTR Wheels
Tein NA suspension
D2 356mm brakes
Aftermarket exhaust
Nistune
R34 GTR front seats
Would've thought at least $30k based on the above.
My car is by no means flawless but was still valued at $40k without even trying....
  • Like 1
I've had the same experience talking to NRMA as mr_rbman.
$40k was agreed upon without mentioning any modifications I'd done, I recall the premium for me was around 6-700/p.a.
I'd hit em up for 45k and see what they come back with.
(I didn't go with them as the policy didn't suit my requirements in some areas)
  • 3 weeks later...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
