I have a 2009 Skyline crossover (370GT) and yesterday I was happily driving along with the airconditioning on and the car seemed to hiccup a couple of times and as I pulled up to a red light it stalled... I restarted the car and immediately heard a strange noise that sounded like (for some reason) the AC compressor? I flicked the Aircon off and the noise immediately stopped and the car carried on fine...
Pulled off onto a quiet road and with the car sitting still in park, I turned the AC on again... There was a cyclic noise, a bad noise - and the engine revs dropped significantly in time with the bad (graunchy) noise - every 3-4 seconds...
Turned the Aircon off and drove home with no issues at all.
I popped open the bonnet today and turned the engine on (again, in Park) and no issues - but when I turned the AC on, it again made a horrible noise... By the time I got out of the car and around to the front to look and see if I could see anything (fat chance with how tightly it's all packed in) there was smoke coming up from the front of the engine. Dived back inside and killed the engine of course.
The smoke was not oil smoke - it smelled acrid - like burning plastic or rubber.
Does this sound like a toasted/seized AC compressor? If that's the case, what am I up for? New compressor, system recharge and possibly a new accessory belt + some labour?
What else might it be? I'm probably going to take it in tomorrow to have someone look at it but if there's a common failure or conventional wisdom on this then I'd love to be prepared.
I'd hate to think what may have happened if I hadn't noticed the noise and turned off the aircon within 4-5 seconds of noticing the noise/smell each of the 3 times it happened.... It took no time at all to generate significant amounts of smoke. (FWIW - I do have a fire extinguisher in the car beside the spare wheel and one on the wall of the garage about 5 metres from where I was standing)
Cheers - Neil G
Edited by talkiet
it does sound like a seized compressor, the smoke would have been the slipping belt, much longer and the belt would have likely just snapped.
As for the repair.. I would guess at minimum you would be looking at a new compressor, and I would replace the belt too, then a leak check and gas recharge.
At worst, the failure could have pushed metal fragments through the AC system and the whole system could need to be flushed and some other components possibly replaced if they can't be properly flushed out.
Thanks for that... It was only the last of the three events where I saw smoke and the other 2 were definitely still producing some AC - it was pretty clear there was some movement in the compressor - it was slipping, not seized... It may we have completely seized now though with the last one. I'll throw it at a professional tomorrow and hope for the best - thanks for the quick confirmation I'm probably on the right track at least.
Cheers - N
Ouch - just had a look at the cost of a new compressor from Japan... $900 USD excluding the clutch, $280 for the clutch. I wonder if I could get incredibly lucky and it just be the clutch that has failed?
Cheers - N
From what I've seen in the past on similar issues, it's most likely the bearings. If it were clutch, the A/C would never engage and that pulley would continue to rotate freely. The fact it only seizes when the A/C is on means the clutch is engaging but the bearings are probably locked solid.
But that's just a best educated guess. You'll find out when you get the report back from the A/C guy. Good luck!
I phoned an aircon place this morning and described the symptoms in detail... The guy said that his first guess was the bearings either badly on the way out or actually locked solid. Hopefully it hasn't blown up the entire pump...
I'm dropping the car off in the morning and for the sake of completeness I'll update when I have a diagnosis
Cheers - N
Ugh... system degassed and drained. There is a small amount of crap in the fluid and the bearing is fine... The resistance is coming from the compressor itself. So they are looking for a replacement pump and I am steeling myself for a significant expense :-(
Fortunately the car is still perfectly usable in the current state and the pressure interlock means I can't even accidentally turn on the AC pump, but I can still use the heater ok.
Cheers - N
Bummer. It's easy to keep the A/C from engaging accidentally in a worst case scenario anyway ... just unplug the electrical connector which engages the clutch.
At any rate, not the best outcome but shit happens with these money pits called cars.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
