Hi all,
thinking about buying one of these for an oil cooler set up. i like the built in thermostat and i really dont want to fit a relocator.
the hicas is removed so there is more room.
does anyone here have it fitted to there bnr32? to me it looks like there isnt enough room. am i wrong?
pic of said sandwhich plate
nengun-3025-04-greddy-oil_sensor_adapter
Hi all,
Pictures and information in my build thread on page 6. NO CLUE about factory manifold and such, but I'm sure it's possible. I had mine in several different arrangements starting with your idea, and then moving to the final idea of relocating the oil filter as well... Note where my temp pickup is located, this is on the RETURN side from the oil cooler so that you know what the temp of the oil is going into the engine.
Need to remove standard oil cooler
The heat exchanger? You don't. I've fitted a few of these now to 32, 33 and 34 and they all fit. They're a little annoying because where the cooler hose comes from is very close to the engine mount, I'm talking 1cm close. It can be done and they're actually a great piece of kit that after fitting 10+ of them I put one on mine as well.
Well there you go
Also the two additional fittings they send are blanked. They also sell some that are tapped 1/8 but this is NOT NPT, it's PT (Japanese). I drilled and tapped my blank ones for my temp and pressure sensor pickups.
was thinking that.
i noticed the coolers with the -10 outlets are considerable cheaper than the -12 ones.
im thinking most people buy the -10 ones?
in my mind im thinking bigger is better, no?
what are peoples thoughts on buying a oil cooler with -10 outlets and buying a -10 to -12 hose end?
was thinking that.
Also interested in reasoning of -10 vs -12
I would have thought you may see a pressure drop?
In the process of fitting my oil cooler setup without relocation. Extra parts required on top of kit was
oil filter stud - purchased from kudos Motorsport
Trust/greedy sensor adapter to fit factory oil pressure sender. The oil temp sensor won't fit unless you get an adapter to step up. I am going to be running aftermarket oil temp/pressure gauge which will come with correct sensor fitting 1/8 npt if I'm not mistaken.
I have not fitted a relief valve to my N1 block but will be running a filter that runs one.
I have chosen to remove the heat exchanger but this is not a must. Clears up a lot of space which I like. Obviously the factory coolant lines that feed heat exchanger will need to be bunged if going down this path.
Manifold is fitted in photo.
Edited by wld093
1) I don't think the hole from the block that sends oil is 1/2" in diameter but it's been a while since I looked at it. -10AN is approximately .5" in diameter and is AMPLE (IMO) for the oil flow in most engines unless you are running something crazy I don't know about.
2) The Greddy kit fittings are -10AN fittings. I'd assume they would send -12AN if it were required for our engines.
looks great. from the replies in this thread i have decided to keep the factory heat exchanger so i dont see why i would need the additional sensor adapter. i was however under the impression that the sandwhich plate came with a stud. ill have to check what i have bought.
after all that i bought i the -12 version. ill be going -12 everything.
I am wondering what the oil flow is if you have the factory exchanger in place. I have mine laying around and may want to see what the flow is doing before you decide to leave it. If it's first in line the temp reading won't be what's actually going back into the engine and if it's last in line the work from your external cooler would be undone from the exchanger reheating it.
Just a thought. Oil flows out from the block on the outside of the oil boss and back into the engine through the center bolt FYI.
  • 3 months later...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
