I'm thinking of changing my alternator out as the car is 20 years old now and the chances of it screwing me on the side of a road somewhere increase as the years do.
I found a very well priced option from circuit sports in the US (available through www.frsport.com or search circuit sports) which is around USD$185 plus shipping (sorry cant post the link, my browser is playing up) but Im unsure as to whether this is worth it or not.
Does anyone have experience with this brand's alternator (or infact this brands products)? whats the quality and fit like?
thanks
https://www.sau.com.au/forums/topic/464559-circuit-sports-alternator-any-good/
Using one atm, can't fault it. Voltages have been rock solid.
I went through 2x used R33 alternators, all had the same issue. Idles at 13.8, rev it and it drops to like 12v thus the constant misfiring.
Bought a brand new CS one for less than the price of reconditioning the OEM alternator and it has been good (so far).
  • Like 1
  • 2 months later...
  • 3 months later...
On 7/30/2016 at 5:50 PM, ausdrift said:
For the record, I did end up buying one. It only needed a very minor modification to fit and seems to work fine. Looks nice and shiny too
Looking at getting one of these, what needed modifying to make it fit?
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
