Hi.
Have setup wasted spark with holden coils on a R32 S1 RB25 but now the issues is that the ECU is getting two pulses for no1 cyl spark as the cyl1/6 and cyl1 sensor wire are bundled. It's quite obvious when under a timing light, the timing is jumping all over the place.
I've spend a few hours trying to remedy this with a diode but no luck what so ever, talk about a waste of time...
Anyone have experience or knowledge about fixing this, I really need to sort this out. The car goes fine but can tell something is not 100% with the ignition.
Cheers!
https://www.sau.com.au/forums/topic/464671-wasted-spark-help/
Nothing tells the ecu when a coil fires.
The ecu tells the coils.
The sensor wire is there for checking timing, doesn't work properly with the majority of timing lights anyway
Seeing as you have plug leads now that's how you check the timing, by clipping between the coils and cyl1
What he said ^.
The input to the ECU telling it "about" cylinder 1 is in the CAS.
The ECU will output on 1 of its 6 ignition according to what angle the CAS says the engine is at. The appropriate coil will fire. When you go wasted spark, you now have 2 outputs from the ECU firing a coil.
I do not know if the stock ECU is actually going to be happy with having outputs effectively paired together, and maybe you do indeed need a set of 6 diodes to stop them backfeeding and causing it to go emo. Or maybe it will be fine.
It sounds like you have Holden coil packs that do not have their own inbuilt ignitors and you are using the Nissan ignitor pack on the top of the engine. (I gather this because you talk about using the black wire loop to trigger the timing light). In this instance, that ignitor module will in fact be isolating the commoning up of coils from the ECU, so what I said above about the ECU being happy/unhappy about it probably goes away.
In which case, the whole thing collapses to what Ben said. If you are trying to trigger the timing light from the loop, you will be getting 2 pulses per ignition cycle on it, instead of just the correct one for cylinder 1. Which will give you crappy results. If you use the normal inductive trigger on a plug lead, you should be fine.
Here is how the setup is wired up, As far as I understand the red wire is sensing when cyl1 fired so the ECU can set electronic timing but since cyl6 trigger wire is also connected to this it upsets the ECU (Please correct me if I'm wrong!). Firing order is 1-6 3-4 2-5 so the there's a second pulse not even a second later. I tried connecting cyl1 trigger wire and the red wire together -> diode -> cyl6 trigger wire -> coil but that resulted in cyl1 not firing even though it had spark.
Timing was checked via plug lead of course. Timing is jumping about 4 degrees backwards and forwards couple of time every second through the rev range.
Gonna go see a sparky tomorrow and get some advice.
Edited by ErOR
Oh no....your using the 6 cylinder commodore coils.....please tell me atleast your not attempting to use the ignition module that's ment to sit below them? If so forget it. If however your trying to use just the coil packs(unsure why as there crap and fail so much and I'm unsure if the dwell is even compatible) then yeah you need to bridge the inputs to the ignitor then only use 3 of the outputs yet it won't effect the timing light as its always going to be firng at the same time relative to crank position
The ignition module is stock s1 rb25 one and the coils are VN I believe. Dwell time is probably not right but I'm just trying this out to see how I go then later I'll make a proper setup.
Bridge what inputs? It's impossible to adjust timing right now.
Essentially your saying I want to change injectors yet don't want to worries about pulsewidth just see how I go at first. Dwell is the most important setting for the coil, to little and it won't run to much and you destroy your coils.
that makes no sense
Did you not realise yet that I'm trying to learn and am a total newb?!
We'll ignore the total newb aspect, because using wasted spark coils is already a sure sign of that.
Let's start at the beginning. There is only 1 ignitor we're talking about. It is the Nissan one that lives(d) on the top of your coil cover. Scott's instruction was to bridge the inputs to that ignitor. That means, for each of the ECU outputs (that I first posted about) you join together the pairs that fire on the same coil. Join 1 + 6 from the ECU for example. You do this on the INPUT side of the ignitor. Then you only use 3 of the ignitor channels. So you hook up the paired 1+6 signal to either the 1 or 6 channel on the ignitor and then you take the output of that to the coil that you need to trigger - making sure that you don't pass it through the Holden ignition module on the way to the coil primary.
But in reality, the smart way to do this is to throw the waste spark business in the bin and buy some decent coils.
Edited by GTSBoy
  • Like 2
the firing order is 1 5 3 6 2 4
So you need to double up these outputs coming out of the ecu
1 -6
5-2
3-4
Together going into the ignitor.
Then out of the ignitor you connect the 3 channels to the wasted spark coils. do not connect any other wires to these.
In this setup you are better off buying a good 3 channel ignitor to replace the standard nissan one (alot less confusing)
Also bare in mind that commondore v6 coils need a massive dwell to charge up, if you are running a aftermarket ecu this is OK but it will not work with a standard ecu.
  • Like 1
Did you have a charisma by-pass per chance?
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
