hey i have an r33 gtst s2 with a dead alternator, now the stock one is 80a but i wanted to upgrade to something with a bit more grunt so i was thinking of a gtr one which is 90a. Then i decided to try see what other ones would fit and i found someone saying that an infinity l30 one fits, it is 130ai think they said but i was wondering if anyone here has actually put one of these in or some other type of one, i know thereis a nissan quest one you can put in but it needs a modified bracket and some grinding work so i want one that is pretty much a straight swap.
What about one from a 300ZX?
Anyways please let me know if you know of any that will fit straight in and what amps they are. And let me know if you know about the infinity one
Thanks guys
https://www.sau.com.au/forums/topic/464866-alternator-options/
Bosch one fits right into s2 r33, is brand new n cheap.
I did that, didn't like it.. they don't like low RPM.. voltage drops pretty quick at about 700rpm.
I pulled it out and went a Circuit Sports 90AMP one from frsport - couldn't be happier
i dont want to spend quite that much on an altetnator, i just want a secondhand 90a stock alternator, im after either of these two model number alternators:
23100-70T05
LR190-722
or
23100-70T06
LR190-722B
i think there right, so if you have either or these two 90a alternators laying around please let me know thanks
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
