been reading a few posts about gtr bovs..seems to be a few dif opions...
tested mine yesterday with an air line and tee fitting with a reg to put air on both sides of the bov at the same time to see if it holds say 20psi or more...
seemed fine at even much higher than 25psi...so whats the benifit of after market bovs like the greddy type r etc....
is the air flow of bigger turbos the reason they start to open at higher boost levels...
cheers..
https://www.sau.com.au/forums/topic/46513-gtr-bovs-max-hp/
Yeah Ronin, that's the Trust 16 row oil cooler kit, I learnt the hard way...
Sent it back to Japan and got the HKS 16 row oil cooler kit which is mounted on the passenger side inner fender... only to find out that it doesn't accomodate for the series 3 xenon headlights...
I hate oil coolers!!!!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/46513-gtr-bovs-max-hp/#findComment-944309
Hey JAGR33, I thought the Trust mounts in the LHS (passenger) fender? Maybe just for R32.
Got me worried now. They have one that they say mounts 'horizontal mount' - does anyone know what that's about or where it is exactly? Sorry to hijack, but I want to know if there is a Trust oil cooler kit that fits with the factory BOVs :P
https://www.sau.com.au/forums/topic/46513-gtr-bovs-max-hp/#findComment-944364
Ronin 09- yeah the kit I got was for an R33 GTR, and it was definetly mounted on the driver's side, ask Gerald he was there when I tried to fit...
Horizontal mount is underneath the radiator and the cooler faces down towards the ground, and is fed air through an air dam.... Don't know if they are practical though....
https://www.sau.com.au/forums/topic/46513-gtr-bovs-max-hp/#findComment-944594
Emre- the hoses cleared the back of the headlights, was a very tight fit... The main problem encountered was where the oil cooler core sits, one of the fittings that goes into the cooler itself was in the way of the little black box bolted underneath the xenons to run the gas discharge, was a big headache!!!!
Ended up unbolting the little box underneath the headlight and relocating a little lower so it wouldn't hit the fitting...... Got there in the end!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/46513-gtr-bovs-max-hp/#findComment-944652
Emre- yes the catch can was a problem too, but where one of the fittings goes into the core itself is pretty much directly under the passenger side headlight..... Well the xenons have a little 'black box' which controls the gas discharge, this was hitting the fitting on the oil cooler core so had to relocate this little box.....
Bit hard to explain......
https://www.sau.com.au/forums/topic/46513-gtr-bovs-max-hp/#findComment-944674
Does anyone know if you can let the stock gtr valves breathe straight to atmo?
I upgraded my cooler & therefore couldn't put the recirc piping back in so I changed the valve. Still got the stockies so I would put them back in if I could get away with it.
I don't see how this would be a problem in terms of boost leak (unless they have the little bleed hole like a GTS-t BOV). It should only really affect stall and mixtures.
https://www.sau.com.au/forums/topic/46513-gtr-bovs-max-hp/#findComment-944852
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
