Hi All,
Another DIY for those interested
Requirements:
- New bush (brass or OEM will suffice)
Tools:
- 10mm socket with an extension
- Ratchet
- Hammer
- Block of wood (is this even a tool)
- Bench vice
Difficulty: Low
1) Start by unscrewing the shift knob
2) Remove the ashtray and the screw from behind it
3) Grab the shifter surround from the bottom side and pull it upwards
4) Undo the bolts securing the shifter ring (possibly the wrong term)
5) Remove the rubber boots and sleeves as shown (including the shifter ring from above)
6) Remove the boot that covers the hole for the shifter where it enters the gearbox to reveal a big circlip
7) Using circlip pliers remove the circlip from the opening and lift the shifter out
8) Put the old bush in a vice and bend it till it pops off
9) Clean the surfaces and apply some gearbox oil to the ball where the new bush will seat
10) Find a nut that matches the thread of the shifter and screw it onto the end of the shifter
11) Put the bushing on the end of the shifter and place them both against a block of wood
12) Using a suitable hammer, hit the nut hard and the bushing should pop into place
I took the opportunity to replace the boot that covers the top of the gearbox as mine was ripped. It may be worthwhile changing yours while you have it apart.
Installation is reverse of removal - Be careful as the circlip can be quite painful
Bonus stage - Paint the shifter ring if you have time - No one will see it but if you're like me, it will annoy you.
I decided to replace the OEM bush with a brand new one and do away with the brass one. I might go with the brass one in the future but for now brand new OEM is fine.
If you have any questions don't hesitate to ask.
  • Like 2
https://www.sau.com.au/forums/topic/465322-diy-how-to-change-r33-shifter-bush/
Great write up thanks
This is actually on my list of things to do today
Thanks Reuben! hope it helps
Great write up. I've added this to the tutorials list.
Thanks Christian! Are you able to assist with the title change? Should be shifter not s-hifter lol.
Great write up Jacob!
Cheers Josh :)
Hey man, I ain't got no vice, how hard was it to take off old bush?
It's not too bad - See below (could also use a pair of vise grips)
If you got no vice. With a fine tooth saw just cut around the old bush to weaken it then pull off with pliers.
This would certainly work but you could melt it off because it's only plastic
Try not to destroy it (although saw and fire will) just in case you have problems with the brass bush or don't like the feel.
Also just to add as a sidenote.
Removing a shifter with a brass bush can be kind of difficult as the brass bush can dig into the insert slightly. If this is the case and the gearstick wont pull out, give it a few sharp taps with a mallet and it will become free.
Exact problem I had with mine when I took it out.
Thanks for the tip!
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
